Bypassing the CCRM
Old Aug 19, 2010 | 03:45 PM
JackBlaximus's Avatar
JackBlaximus
Exclamation Bypassing the CCRM
I'm Jack, and I have had my Mustang for a few years now, and personally know the man who sold it to me. In the past year and a half it has been consistently overheating. I replaced the sending units, and that didn't help. I then replaced the CCRM, and it helped a little, but it seems my fan still won't kick into high speed. I'm curious if anyone can give me some pointers to bypass the fan speed modulator and just have the fan running at high speed at all times. I figure this would be plausibile, considering all fans used to run so long as the water pump was running, since the fan was mounted to it in old cars. I don't know much at all about cars, so any help at all would be much appreciated.
Old Aug 19, 2010 | 03:52 PM
Timspony's Avatar
Timspony
SVT Section Moderator
Welcome to MF! ... GL!
Old Aug 19, 2010 | 08:06 PM
05 Mustang's Avatar
05 Mustang
welcome
Old Aug 20, 2010 | 09:25 AM
CWyler's Avatar
CWyler
Welcome to the forums!
Old Aug 20, 2010 | 09:59 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
most fans on older cars where thermostatically controlled so no they were not in theroy engauged all the time, when does the car overheat?? highway??, city??? and high speed doesn't come on until 227' ish iirc??
Old Aug 20, 2010 | 01:25 PM
MOOK3456's Avatar
MOOK3456
If you trace the wiring back you should see it connects to a relay before connecting to the solenoid. Disconnect it and run it straight to the solenoid only to test that your fan clutch isn't gone. I wouldn't leave it that way, it will burn out before long. If the fan is capable of running high then I'd look at the thermostat or the relay as possibly the cause.
If it won't run high in testing, you probably have a bad fan clutch.
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
Roxon68
Mar 17, 2016 08:13 PM
TimeLord101
Sep 4, 2015 09:27 AM
1999350m
Aug 24, 2015 07:06 AM
90Mustangfan
Feb 1, 2005 12:20 AM
