High Idle Problem
Old Aug 14, 2005 | 05:10 AM
Dangerfield23's Avatar
Dangerfield23
Default High Idle Problem
I recently installed a '99 Explorer intake on my 5.0 and I now have an idle problem. After hard excelleration it will not come back down to an idle, it stays around 2k rpm. I can unplug the IAC and it will idle back down to normal. I have replaced the IAC assembly, I installed a new computer, I installed a new throttle body, and I have a spacer block between the IAC and throttle body for more precise idle adjustment, but I still have the same problem. Anyone ever have this type of problem or have any tips?
Old Aug 14, 2005 | 08:02 AM
03GTType's Avatar
03GTType
Default RE: High Idle Problem
did you by any chance use the maf off of the explorer too..
Old Aug 14, 2005 | 02:42 PM
99saleen351r's Avatar
99saleen351r
Read this post and do what is said it will fix your problem.Try a search next time and chances are you'll find the answer to your question
https://mustangforums.com/m_646273/tm.htm
Or this one http://forums.stangnet.com/showthread.php?t=470711
Old Aug 14, 2005 | 03:49 PM
Dangerfield23
ORIGINAL: 01GTType
I did not use the maf off of the explorer. I was told that it was not necessary. I could be wrong.
Old Aug 14, 2005 | 03:50 PM
Dangerfield23
ORIGINAL: 99saleen351r
Isn't a restrictor plate essentially the same thing as the bypass plate I have? I can adjust the screws to restrict air flow.
Old Aug 16, 2005 | 05:45 AM
Dangerfield23
Thanks for the info, but I tried the restrictor plate and it didn't fix my problem. It almost helped a little, but it didn't fix it. It also caused some additional problems so I took it off. Some of the feedback I have gotten in other forums have suggested that I may have a vacuum leak that I have overlooked. I figured if it were a vacuum leak it would idle high no matter what. But I can unplug the IAC and it idles fine. Would a vacuum leak somehow make the computer open the IAC?
2007StangV6
Jan 28, 2016 06:09 PM
Oct 5, 2015 06:07 PM
Emblazoned
Sep 3, 2015 10:45 PM
Sep 3, 2015 07:14 PM
5.0 kevo
Sep 3, 2015 06:24 PM
