Carb Related Question
Old Sep 24, 2010 | 07:04 PM
rhank88's Avatar
rhank88
Default Carb Related Question
Just bought a car with a 331 dss stroker. It has a carb spacer that is probably 2" at least. Problem is, the air filter doesn't fit with the hood down.
Question one:
How does the carb spacer come off?
Question two:
Will this affect any tuning of the carb?
I am obviously a beginner with this stuff. Any help is appreciated
Old Sep 25, 2010 | 05:52 AM
alfred9744's Avatar
alfred9744
once u unbolt the carb u can take off the spacer,no noticable affect on tune without spacer, but the spacer helps keep the fuel in the carb bowls cooler,by dissapating the heat from the intake manifold,u should replace the spacer with a one inch high one or search for an air cleaner with a lower profile. without the spacer when the motor is hot the fuel in the bowls can boil over,and drain into the intake making warm start ups hard.
some old hot rodders used to make spacers out of wood,very effective on keeping the heat away from carbs. if u smell fuel when the car is off after a run u might need 2 lower the bowl floats
Old Sep 25, 2010 | 06:38 AM
rhank88's Avatar
rhank88
Thanks for the detailed response. That is what I needed.
Old Sep 26, 2010 | 05:37 PM
rhank88's Avatar
rhank88
Okay, so another question...
If I plan to use no spacer, should I use a gasket with the four holes or an open one? It is a Summitt Brand carb.
Thanks!
Old Sep 26, 2010 | 06:17 PM
alfred9744's Avatar
alfred9744
i would match the gasket to the opening of the intake if open use an open gasket.
Old Oct 2, 2010 | 02:33 PM
Jfsram's Avatar
Jfsram
Spacers are also for tuning the power curve. They increase the plenum volume. If you have the hood clearance. Spacers often pick up the 1/4 mile trap speed. So yes it is a tuning tool.
Old Oct 2, 2010 | 09:18 PM
rhank88's Avatar
rhank88
Thanks to all the responded. I worked it out with a one inch spacer.
Ipaman
Sep 22, 2015 07:01 AM
uberstang1
Sep 20, 2015 06:42 PM
Sminemann
Sep 17, 2015 09:24 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
