Help with bulb replacement
Old Oct 30, 2010 | 06:54 PM
RideThePony14's Avatar
RideThePony14
Default Help with bulb replacement
Hey guys, i have a 2005 mustang gt and i noticed that the right rear side marker bulb was out (the light right after the rear wheel). I am not sure how to change this bulb and i don't want to risk breaking the lens. I also have the Shaker 1000 system so i have the subs in the trunk on that side which may cause a problem. If anyone has done this before or knows how to do it please help me. Thanks.
Old Nov 2, 2010 | 02:33 PM
Alec's Avatar
Alec
I had to take both out when I installed the GT/CS rear. It's pretty easy, you could partially take the bumper cover off so you can get a good hand on it if you're not sure.
You could also try to gently push it in and it should pop out. Then pull the whole light marker out through the hole and then switch the bulb out. Kinda hard to describe
5.0muscle
Jan 11, 2016 01:17 PM
9550
Oct 26, 2015 05:01 PM
unit91
Sep 15, 2015 09:53 AM
MusicCity615
Sep 12, 2015 07:05 AM
Art161
Sep 9, 2015 10:33 AM
