What HP to expect?
Old Nov 5, 2010 | 10:47 PM
Droptopfiveo's Avatar
Droptopfiveo
Default What HP to expect?
About to start building a motor for my 93 Mustang GT Conv. Below is a list of parts looking to install. Can you all assist with what type of HP I'm looking at with this setup?
Stock Block with Forged Pistions
AFR 205 Heads
Trick Flow Street Heat Upper/Lower intake
Trick Flow Roller Rockers
Trick Flow Roller Lifters
Trick Flow Cam
75MM Accufab
65MM Prom M Mass Air Meter
BBK Underdrive Pullies
Headers
Flowmaster Catback
Mach Highflow H-Pipe
Thanks in Advance
Old Nov 5, 2010 | 11:01 PM
a_penquin's Avatar
a_penquin
not enough
Old Nov 5, 2010 | 11:13 PM
Droptopfiveo
Originally Posted by a_penquin
not enough
Penguin,
It's never enough, now you got any idea on what this setup would produce?
Old Nov 5, 2010 | 11:20 PM
a_penquin's Avatar
a_penquin
Build it and put it on the dyno, thats the only way to know. I can tell you numbers all day to either get your hopes up or put you down but it means nothing in the end. Get it on the dyno when its done and let us know what its making.
Old Nov 6, 2010 | 03:53 AM
Bladerunner's Avatar
Bladerunner
not enough
It's never enough I agree.
He will install this set up be happy for alittle bit and
want more power again.
Good choice on the AFR cylinder heads though they
will benefit you down the line.
Definitley have your mustang dynoed after you have you set up installed.
Old Nov 6, 2010 | 07:36 AM
GreyStang's Avatar
GreyStang
What are cam specs? How much compression? Are you setting it up for stictly premium octane fuel?
Old Nov 6, 2010 | 11:46 AM
67mustang302's Avatar
67mustang302
AFR 205's are large heads for a 302, you'll need a fair bit of cam, compression and rpm to make them work right.
CS2007
Jun 25, 2019 09:45 PM
Nov 18, 2015 01:34 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
treesloth
Sep 28, 2015 07:03 AM
