NO FUEL!!!!!
Old Dec 23, 2010 | 08:22 PM
brandon-88's Avatar
brandon-88
Default NO FUEL!!!!!
i have a 89 notch and its not getting any fuel ive change fuel relay and checked fuel saftey switch, ive lost a ground somewhere cause i have power to the fuel relay but it dont click when i turn teh key on does anyone know what the problem could be? im lost!
Old Dec 23, 2010 | 08:36 PM
AzPete's Avatar
AzPete
When the key is on, you should have two power sources to the relay......one to power the relay itself and one is power that passes thru the relay to the pump. Sounds like you are missing the switched power. Is there as fuse somewhere?
Old Dec 23, 2010 | 08:55 PM
brandon-88's Avatar
brandon-88
not that i can find, ill tell you exactly what happend freeze plug rotted out car overheated shut it off running fine now it wont start ive checked all the fuses under the dash didnt see any that were blown is there any other you know of?
Old Dec 24, 2010 | 01:07 AM
petrock's Avatar
petrock
Definitely check the fuses. A visual inspection is only a basic check. A proper test is done with a multi-meter or fuse tester. Most fuse kits come with a fuse tester.
I'm not sure that the relay will click if the circuit is broken somewhere (e.g. the fuel pump is disconnected). Have you checked if the fuel pump is getting power? If its not, then start walking up the wires to find the brake. Good luck...
Old Dec 25, 2010 | 11:40 PM
2tonterror's Avatar
2tonterror
Try grounding the relay directly to the neg side of the battery with a jumper wire. If the relay works with the jumper wire, then you know the ground is bad.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Sixx
Oct 5, 2015 07:36 PM
svfetter
Oct 5, 2015 11:39 AM
mrappe
Sep 26, 2015 10:16 AM
