Gas tank issue
Old Jan 23, 2011 | 04:47 PM
legend05stang's Avatar
legend05stang
Default Gas tank issue
Curious how many Mustang owners are having issues with the gas tank. In the past few months whenever I stop to fill up, I am unable to get more than about a gallon of gas in the tank before it begins turning off. Then it is a continuous battle between me and the car to get the tank full. I have to pump it very slowly and it takes several minutes to get 2/3 of a tank if I'm lucky. It has been enough of an issue for Ford to issue a bulletin but they are unwilling to recall the tanks or fix it. The solution is a new gas tank at $1000 plus labor. Please comment if you are experience a similar issue or know someone who is. Thank you.
Old Jan 23, 2011 | 06:38 PM
MU71L4710N's Avatar
MU71L4710N
its a much easier fix than that...
you can either pull the gas nozzle out about an inch while your filling, or if you uhh...how do i say this... dont let the nozzle just drop in and sit into the hole, but kinda pull the lever towards your car. mine shuts off occasionally if i just drop it in and let it sit but if i do either of the above no problems.
Old Jan 23, 2011 | 10:14 PM
mattstang2007's Avatar
mattstang2007
i have heard rotating the gas pump handle to the left or right and sometime rotate till its upside down. I hear this works
Old Jan 24, 2011 | 06:36 AM
legend05stang
Sorry, but I have tried all of these things. I never put the nozzle allthe way in and still it is an issue. Mine started out doing it occasionally and the suggestions you had worked for a while but no longer. Fords' solution is a new gas tank, they issued a bulletin about the problem. Thans!!!
Old Jan 27, 2011 | 03:29 PM
PNYXPRESS's Avatar
PNYXPRESS
there is no real solution to the problem because of the saddle-style tank design. My '08 has the newer styled tank and it still has problems.
Old Jan 29, 2011 | 10:26 PM
DougFL's Avatar
DougFL
You can try cleaning or replacing the EVAP cannister/emissions system and/or re-angle the fuel filler neck as it is usually just slightly too long and causes the station pumps to detect higher pressure and shut off before the tank is actully full.
It definately is annoying. When I had this problem, I use to not hold the pump all the way down - just hold it in half speed and it would not stop but that got very annoying. I replaced my EVAP cannister and filter and shortened and re-angled my fuel inlet filler neck hose about 2 months ago and have not had any issues yet. Now maybe as time goes on and my EVAP gets a little dirty, Ill have the same problem again? - I guess we will see. But it sure beats the costly Ford "fix" with the new tank.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
Oct 7, 2015 07:02 PM
rksnow1
Sep 14, 2015 08:46 PM
zachary1988
Sep 4, 2015 03:04 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
