car problem
Old Mar 23, 2011 | 09:04 PM
amp009's Avatar
amp009
Default car problem
okay, so today when i was coming from work it was raining very hard i went through a puddle of water couple of times and car made this whining noise and when i got home which is only 10 min away i opened the hood smoke was coming out from the front where the fan is not the engine. I tried to smell i couldn't really smell anything but what you guys think may be the fan motor or something. I started the car again and temperature was normal.
thank you.
Old Mar 23, 2011 | 09:05 PM
amp009's Avatar
amp009
and also i was going really slow i saw other cars going like 10-20 mph splashing water everywhere no problems
Old Mar 23, 2011 | 09:12 PM
amp009's Avatar
amp009
you know what i think it might be the bbk filter i have which goes into the fender cuz thats where the smoke is coming from it might've sucked some water. Anything i need to do or just let it dry off.
Old Mar 23, 2011 | 11:19 PM
amp009's Avatar
amp009
just drove the car have my friend look at it everything is fine we think the water might've hit the headers thats why the smoke was coming out. There is no more smoke now the bbk filter is pretty dry no water there. i have a question the fan front of the engine by front bumper when does that turn ON. Does it only turn ON when the engine gets hot right?
Old Mar 24, 2011 | 01:52 PM
Dave19525's Avatar
Dave19525
Our cars run at about 200 degrees so if you splashed cold rain water on any part of the engine it will almost instantly steam. If you saw steam coming from the fan it was probably actually coming from the radiator. Also as soon as you turn the car off everything get hotter cause the water is no longer flowing. If you airfilter is dry and still has enough oil on it you shoule be ok. Also yes the fan only turns on when the water/antifreeze reaches a certain temperature.
Old Mar 25, 2011 | 12:01 PM
amp009's Avatar
amp009
yea, thank you for your reply. I was just scared that i might've screwed up something already.
djbigskrilla
Sep 20, 2022 01:04 AM
FD725
Aug 23, 2015 06:43 AM
jjwinel78
Aug 17, 2015 03:34 PM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
