emissions problem, Please Please help me..
Old Mar 30, 2011 | 01:38 PM
Elkakandkss's Avatar
Elkakandkss
Default emissions problem, Please Please help me..
Hello all, I have a 2006 Mustang gt and I will not pass emissions, the emissions paper said (Heated Oxygen Sensor) NOT READY. There is no check engine light on and I believe that the previous owner may have put a program or a tune on the ecu but not 100% sure. Is there anything I can do to make the car pass? I have been driving the car for a yr like this and have over 10 tickets, its my only vehicle I have to drive. If any one has any suggestions please help me out. Thank you for all of your time.
Old Mar 30, 2011 | 02:47 PM
ZeroTX's Avatar
ZeroTX
Not sure what to help you out with there with 10 tickets man, wow, but have you recently disconnected the battery? Usually NOT READY means that it hasn't had enough cycles or miles since the last battery disconnection. You cannot just disconnect it/reconnect it and then go back to the inspection station. It has to run through enough cycles and miles.
That said, it wouldn't hurt to hook up to an OBD2 checker and see if there are any codes. You can do this for free at Autozone or O'Reilly.
Old Mar 30, 2011 | 08:35 PM
Elkakandkss
Battery has not been touched in over a year, I dont know if there is was I can tell if there is a tune on the ecu, no check engine light, runs fine. I need to pass emissions the its coming back oxygen not ready.
Old Mar 30, 2011 | 11:41 PM
ZeroTX's Avatar
ZeroTX
Do you have catalytic converters?
Old Mar 31, 2011 | 07:50 AM
LilRoush's Avatar
LilRoush
If the previous owner 'tuned' it and had the O2 sensors shut off, you'll need to have them turned back on in order to pass.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
rksnow1
Sep 14, 2015 08:46 PM
