Fly by wire Throttle Body
Old Mar 23, 2011 | 09:02 PM
blumax2007's Avatar
blumax2007
Default Fly by wire Throttle Body
Anybody know if the newer 2005+ mustang fly by wire thorttle body will fit and or work on an older 4.6 2 valve??
Old Mar 29, 2011 | 09:53 AM
bbktech2's Avatar
bbktech2
No it won't. The new 05+ is a twin bore throttle body and the earlier 4.6L 2v's were single bore.
Although. The 4.6's come in 70 and 75mm sizes and the 05+ V6's are also single bore, 70mm, and drive by wire. You would come alot closer to mounting and using the V6 one. Now you just have to figure out how to control it.
Old Mar 29, 2011 | 01:06 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Why would you want to do this?
Old Mar 30, 2011 | 01:10 PM
blumax2007's Avatar
blumax2007
I have a 1978 F100 and I'm thinking of dropping in a new 4.6 or 5.4, I'm a disabled vet and an amputee right leg, with the fly by wire TB I can just move the gas pedal to the left and I don't need handicap controls then. I have a 2007 GT/CS and I moved the gas pedal over soddered in some extra wire for clearance and boom I have a factory looking setup for me to drive the car.
Old Mar 30, 2011 | 01:35 PM
Torch_Vert's Avatar
Torch_Vert
That's a very clever solution to your needs. Almost makes you think Ford should offer a simple kit for that to assist those with amputations or right side mobility issues.
Old Mar 30, 2011 | 02:51 PM
ZeroTX's Avatar
ZeroTX
The issue is going to be that the ECM controls the throttle. There's no extra or separate computer for that AFAIK. Best bet to do this would be to get a complete drive-by-wire engine with harness/ECM and put that into the F100.... or on a non-DBW setup, just run the throttle cable to the left-side by making a new hole in the firewall?
Old Mar 31, 2011 | 11:58 AM
blumax2007's Avatar
blumax2007
The cable idea has been hassed through also I need to find a 84-86 mustang 4 barrel carb plate to route the cable, but I like the idea of putting in a modern engine that get more power and better mileage, while also being lighter on the front end!!
Jb145700
Aug 21, 2022 06:37 AM
GimpyHSHS
Sep 18, 2015 12:27 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Webster454
Sep 7, 2015 04:59 AM
