Some advice...
Old Apr 3, 2011 | 01:55 PM
Dmonty420's Avatar
Dmonty420
Default Some advice...
Ive inherited the family Mustang. Its a 3.8l with over 150k on the odo. It was leaking coolant all over the place. So I took the engine out, have it on an engine stand. Sent the heads to a automotive machine shop. And, was planning on dipping the block in acid.Honing the cylender walls, getting new piston rings/bearings and camshaft bearings. But, I just noticed a hole in one of the freeze plugs. Should I just replace the freeze plug, put the car back together and be done with it. Or, send the block to a machine shop and continue as planned. I have the oil pan and timing cover off. The inside of the motor looks pretty clean and solid.
Also what would cause a hole in a freeze plug. Its not corrodid or anything looks like a whole was punched in it. Kinda strange really. Its the plug right behind the driver side engine mount.
Old Apr 5, 2011 | 08:53 AM
mustangman02232's Avatar
mustangman02232
You could throw a stroker kit at it while its apart with a mild cam and take your time to gasket match port the heads if you have the money, it will provide a nice bump in power.
not maintaining the coolant could of caused the freeze plug to pop
TammyKeller
May 29, 2014 03:27 PM
bunnielebowski
Jan 27, 2014 07:23 AM
yiannisthegreek
Oct 19, 2013 09:06 AM
Milty69
Sep 13, 2013 10:39 AM
l00kitzzlilcj
Aug 24, 2013 05:01 PM
