Battery Light
Old Jun 18, 2011 | 01:28 PM
ANTHONYROBERSON's Avatar
ANTHONYROBERSON
Default Battery Light
Hey!
I just found this site! Can anyone tell me why my battery light comes on briefly while I'm driving, then goes off? It's happened twice. The battery is new (less than 2 months old), and I wouldn't guess the alternator (stock) because no lights are dim or anything like that.
I hope I posted this in the right place. Sorry if I didn't, but I'd sure appreciate some input.
Old Jun 18, 2011 | 08:47 PM
SyNdicateZ's Avatar
SyNdicateZ
hmm Are the negative and positive cables tight and secure on the battery terminals?
I would bring the car in and get the ALT Checked at a local shop..Thats all i got....
Old Jun 21, 2011 | 02:51 AM
petrock's Avatar
petrock
Check the battery connections to see if they are tight or have any corrosion on them. Also check the alternator connections. The battery is primarily used for starting the car. The alternator keeps the car running. Most auto parts stores will check your alternator and battery for free. Call ahead of course.
Might also be worth finding out if you have any codes. Most auto parts stores will rent you the code reader and give you your money back when you return it (net cost = $0).
Good luck...
Old Jun 21, 2011 | 01:17 PM
arabianobsession's Avatar
arabianobsession
I had this happen in my 95 (it has the original alt.). I replaced the serpentine belt with a new one, and because it wasn't "stretched out" yet, it made the alternator light pop on occasionally. It finally quit, but I had my alternator tested anyway, and it's only putting out 70 amps (it's rated at 130). It's been fine for summer driving, but come winter I will have to replace it.
Old Jun 21, 2011 | 02:40 PM
lizzyfan's Avatar
lizzyfan
Underboss
Almost certain your alt is on it's last legs
Old Jun 21, 2011 | 10:45 PM
alexyikes00's Avatar
alexyikes00
Yea.. I would get your alternator checked.. Thaw most likely your issue
Old Jun 23, 2011 | 06:21 AM
Budco's Avatar
Budco
Like the others said, first thing is remove and clean your battery posts and your cable connections, won't believe the problems I'd corrected over the years by doing that. If that doesn't cure the problem, have the alternator checked for max output.
Old Jun 25, 2011 | 11:42 AM
ANTHONYROBERSON
Default GREAT HELP
I went and checked, and both battery and alternator were fine. Yet, the FIRST thing the mechanic said as he opened the hood was "Well, first I'd clean up these terminals and connections. They're not all corroded, but that might be your problem."
Thanks you guys that responded, and double thanks for making me aware of the terminals/connections. I thought they were fine unless you saw major corrosion.
Old Jun 25, 2011 | 07:49 PM
SyNdicateZ's Avatar
SyNdicateZ
You can thank me. I was the first one to suggest it may be the terminals! Buahahaha I WIN!
I Recently had to replace my negative terminal connector. That solved my battery issue..
The terminal connector was in purdy bad shape..
Old Jul 17, 2011 | 07:28 PM
crankedGT/CS's Avatar
crankedGT/CS
im envious of your warning...my alt went out all of a sudden one day on the way to work with no light or warning.... only warning i got was aftermarket amplifiers beginning to distort and radar detector showing low voltage.... charge light never came on even though i drove it till battery completely died (trying to get home and avoid towing)
piotrek53
Oct 13, 2015 06:54 PM
logan409
Sep 26, 2015 07:43 PM
Sep 25, 2015 09:06 AM
Beerman309
Sep 19, 2015 01:16 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
