Tie rod end bolt
Old Sep 1, 2005 | 11:40 PM
razarr69's Avatar
razarr69
Default Tie rod end bolt
Im replacing the outter tie rod end on my 89 5.0 and i cant get the stubborn ****in tie rod end bolt that keeps it from turning on farther off, partially because i think its the inner tie rod slips in the vice grips and then we tryed to heat it up after lettin wd 40 soak in and it still wont bug, any suggestions?
Old Sep 2, 2005 | 12:05 PM
Chopper's Avatar
Chopper
Default RE: Tie rod end bolt
Can you get a Sawzall in there?Do you have access to a die grinder and cutoff wheel?,a dremel tool will be slow but will eventually work.If not,you might have to burn it off with a torch.[:@]
Old Sep 2, 2005 | 03:30 PM
99saleen351r's Avatar
99saleen351r
Some have a spot on the top were you can put an allen wrench in them to keep them from spinning,I know mine does or you can put a jack under it and lift up on it and it should jam it up so it doesnt spin anymore if that fails to go get a tie rod tool and jam it in there and that should work....If all else fails cut it off with a sawzall or a nut splitter
mtgldr
Feb 3, 2024 09:00 PM
maestro1024
Sep 21, 2015 02:40 PM
ctgreddy
Sep 20, 2015 08:35 PM
yourmom6990
Sep 14, 2015 10:52 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
