supposed misfire???
Old Sep 6, 2005 | 04:18 AM
universial's Avatar
universial
Default supposed misfire???
I can't seem to figure out why My 1994 mustang 3.8L V6 is claiming to misfire. ran diagnostics and said that bank 2 was running lean, that the fuel was lean, and that cylinder #6 was misfiring. Checked all the injectors, spark plugs, wire set, coil pack, compression (120lbs), and looked for leaks in the vacumn lines and nothing is touching the problem.... Any suggestions on some stupid little sensor that could be doing this???
Old Sep 6, 2005 | 06:53 AM
p0rsche23's Avatar
p0rsche23
Default RE: supposed misfire???
is ur stang running just fine or what,
i would guess fuel pressure or maf is causing the misfire code..
vargas
Jun 17, 2017 12:17 PM
9550
Oct 26, 2015 05:01 PM
Gene K
Oct 21, 2015 11:37 PM
Omgitsa88Stang
Oct 5, 2015 07:33 AM
bconboy
Sep 21, 2015 12:52 PM
