Sponsored by:
Sponsored by: DashLynx
87 5.0 cranks over but dies immediataley!HELP
Old 09-11-2011, 12:30 AM
bmckenzie
bmckenzie's Avatar
Unhappy 87 5.0 cranks over but dies immediataley!HELP
i have an 87 5.0 gt it has a cam,intake,headers etc.. when i go to turn on the car it cranks over and starts but immediatley dies. i have no clue as to why all of asuden this has happend it has gas in it.? can anyone help? im willing to answer any of your questions that u might have for me to help me figure this out.
bmckenzie is offline
Old 09-11-2011, 06:32 PM
petrock
petrock's Avatar
Battery gets the car started, alternator keeps it going. Most auto parts stores will test your alternator for free, call ahead of course. Also make sure your serpentine belt is tight and not cracked, damaged or slipping. If the belt is not spinning the alternator properly, the alternator won't be able to produce enough juice to keep the motor running...
That is a good starting point... Good luck...
petrock is offline
Old 09-19-2011, 09:45 PM
GT350R
GT350R's Avatar
I say its the ignition switch. I have seen this 100 times.
Try this. Try starting the car and lightly holding the key forward after it starts.
That does not always do it , and the other way is harder. It is disconnecting the wire from the solinoid. One person holds the key at "start" , the other jumps the starter at the solinoid.
If it stays running for either of these, its the ignition switch.
If you dont understand any of these, or if you dont know what the ignition switch is, (no its not the key), then have it done for you.
Or, just have it done. The key has probley been turned 10,000 times or more, and is a crappy dinosaur of a design in the first place. Its the number one reason for old Ford's dying. As a matter of fact, look and see the part number. If it does not have a part number that starts with an "F2..." then its original and was actually a firehazard recall.
GT350R is offline
Old 09-19-2011, 09:50 PM
GT350R
GT350R's Avatar
Incorrect.
Car will run with a bad alternator as long as the battery has a decent charge. If it has enough juice to start, it would have enough to continue running.
GT350R is offline
Urambo Tauro
10-05-2015 09:37 PM
svfetter
10-05-2015 11:39 AM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
treesloth
09-28-2015 07:03 AM
Quick Reply: 87 5.0 cranks over but dies immediataley!HELP
