DPFE voltage too low
Old Nov 29, 2011 | 05:11 PM
midwestmx82's Avatar
midwestmx82
Default DPFE voltage too low
I'm troubleshooting the following codes on my 2000 Mustang V6:
P0401-EGR flow insufficient
P0301-Cyl #1 misfire
P0174-System too lean
My voltage measurement from the signal wire on the DPFE is significantly low compared to what I've gathered from multiple sources at only 0.21-0.28V at idle. I've verified my EGR valve is operational by supplying vaccuum to it which made it run rough as expected. I have also made sure all passageways are clear. One post I read said to monitor the dpfe signal voltage as I applied vaccuum to the ports on the sensor itself and showed no change in signal voltage. This leads me to believe my dpfe is in fact bad. Am I missing something?
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
TfcCDR
Sep 14, 2015 12:08 PM
cbird1177711
Sep 3, 2015 08:43 PM
