Battery dies while driving
Old Dec 24, 2011 | 01:07 AM
bgmustang's Avatar
bgmustang
Default Battery dies while driving
My 2006 v6 convertible Mustang battery died on me while driving. The battery light had come on so i was on my way to take it home and radio turned off, headlights turned off, ABS turned off, in car dashboard lighting turned off, but the car didn't turn off so i drove it home. The morning after i had to jump start and I took it in to AutoZone to have the battery and alternator tested. They tested both the battery and alternator to be fine even though the battery light was still on. I have a warranty on the battery so i had it changed with a new one but the battery light on my dashboard was still on. A day later driving home from work the battery dies on me while driving again.
To me it sounds like an alternator issue but it was tested fine so could the battery be shorting out from faulty wiring or something draining it?
Old Dec 24, 2011 | 11:14 AM
ttocs's Avatar
ttocs
start simple before you start throwing parts at it and check all the conenctions on the alt as well as the factory ground by the battery to ensure they are tight, as well as the battery terminals.
It probably is your alt and it was just the change from cold weather to a hot motor that caused something to expand and make it stop working.
Old Jan 23, 2012 | 03:25 AM
collegekidnlv's Avatar
collegekidnlv
any update on your car? Mine is doing the same thing. I just had the alternator changed two days ago, and the battery is still dying. But seems to have a charge when I let it sit while the car is off.
Old Jan 24, 2012 | 12:22 PM
bgmustang's Avatar
bgmustang
@collegekidnlv
I had my alternator changed it solved my problems, its possible that since your battery continues to die even with a new alt that the battery itself is bad
Old Jan 25, 2012 | 11:05 AM
collegekidnlv
Thanks for the advice. It turned out that i just had a heavily corroded battery terminal stopping the battery from getting a charge from the alternator.
Nick Oliver
Oct 17, 2018 04:22 AM
StalkerGT
Sep 25, 2015 02:41 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
5.0 kevo
Sep 3, 2015 06:24 PM
