Tremec T56
Old Sep 13, 2005 | 11:42 PM
matthockey32's Avatar
matthockey32
I ♥ Acer
Default Tremec T56
is it possible to put a Tremec T56 into an 02 v6? i would like to have some more gears. i like shifting a little too much
Old Sep 13, 2005 | 11:49 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: Tremec T56
they make bell housing that should fit, your looking at about $2500-3000 in parts. Honestly I have a T-56 and almost never use 6th gear. Unless you drive on the interstate for hours on end it is not a practical swap.
Old Sep 14, 2005 | 12:08 AM
matthockey32
I ♥ Acer
ORIGINAL: JD1969
i drive 90 miles to and from work everyday. money won't be a problem.
Old Sep 14, 2005 | 12:31 AM
4600cc's Avatar
4600cc
I ♥ Acer
Traffic averages 70 to 80 MPG where I live, that's 2000 to 2500 rpm in 5th gear, I could use some more overdrive!
Old Sep 14, 2005 | 12:33 AM
4600cc's Avatar
4600cc
I ♥ Acer
Another thing. How the hell did you get this numbers?
Code:
272 hp @ 5250
 312 lb-ft of torque @3900 rpms
 E.T. 13.512 @ 104.14 MPH off the bottle
Is that power and ET on juice or motor? I know you don't have a supercharger yet.
Old Sep 14, 2005 | 01:19 PM
99saleen351r's Avatar
99saleen351r
Advanced adapters I bet has something to make it work but like JD said I never use 6th gear even on the highway I find myself cruising in fifth and sometimes forget there is even a sixth.Its kinda funny acually when people are in my car I'll be cruising for a while on the highway in fifth and shift to sixth and my friends will look at me with a stupid face like what did you just do???6th gear baby!!!!it is good for fuel milage thou but it tends to chug unless im going over 70 mph
Old Sep 14, 2005 | 01:21 PM
99saleen351r
ORIGINAL: matthockey32
ORIGINAL: JD1969
If moneys not a problem why not buy a cobra that has a t-56 and is alot easier to mod??Is the motor on a sixer in the same place as a gt??
Old Sep 14, 2005 | 02:22 PM
JD1969's Avatar
JD1969
ORIGINAL: 99saleen351r
Yup I only shift into 6th at 75 mph or above, my car has around 400 rwhp and it lugs down bad at any lower speed. IMO it's not worth the money and hassle to do the swap.
Old Sep 14, 2005 | 03:55 PM
Fallstar01's Avatar
Fallstar01
It requires a modified cross member, a shorter driveshaft, and I believe it adds weight to your car.
Old Sep 14, 2005 | 04:12 PM
JD1969's Avatar
JD1969
One other thing to know is that the Camaro/Firebird has a very high (numericly low) first gear, I would not condifer using one as a doner unless you change out the gear ratios.
