Tremec T56
Old Sep 14, 2005 | 07:47 PM
matthockey32's Avatar
matthockey32
I ♥ Acer
Default RE: Tremec T56
ORIGINAL: 99saleen351r
ORIGINAL: matthockey32
ORIGINAL: JD1969
they make bell housing that should fit, your looking at about $2500-3000 in parts. Honestly I have a T-56 and almost never use 6th gear. Unless you drive on the interstate for hours on end it is not a practical swap.
i drive 90 miles to and from work everyday. money won't be a problem.
If moneys not a problem why not buy a cobra that has a t-56 and is alot easier to mod??Is the motor on a sixer in the same place as a gt??
because i drive 90 miles to and from work every day. i get around 350-400 miles on a tank of gas. a guy at my work, who has a modded cobra, drives the same distance and gets less than 275 miles per tank. and when i am done with this car a cobra won't have a chance.
Old Sep 14, 2005 | 07:49 PM
matthockey32
I ♥ Acer
ORIGINAL: 4600cc
Another thing. How the hell did you get this numbers?
Code:
272 hp @ 5250
 312 lb-ft of torque @3900 rpms
 E.T. 13.512 @ 104.14 MPH off the bottle
Is that power and ET on juice or motor? I know you don't have a supercharger yet.
on the motor. it is rated at the crank, though.
Old Sep 14, 2005 | 08:04 PM
4600cc's Avatar
4600cc
I ♥ Acer
Yea, ok. Your sig says you have a 2002 Mustang V6. Are those numbers for V6? What did you do to it?
Old Sep 14, 2005 | 09:01 PM
Fallstar01's Avatar
Fallstar01
Good luck with "A cobra won't have a chance". Be sure to show us the size of the turbos you plan on adding and some info on how you'll get the 3.8 to be strong enough to handle it.
Old Sep 15, 2005 | 02:01 AM
92hatchLX's Avatar
92hatchLX
I can't wait to see this build up...
Old Sep 17, 2005 | 12:07 AM
matthockey32
I ♥ Acer
ORIGINAL: Fallstar01
a v6 with a good tune can run up to 18 PSI. try that on GT and watch it go boom. Bazz Clark from Marrietta, GA has a v6 with around 1100 rwhp with twin turbos, but he is a pyscho.
i am getting a forged 4.2 stroker kit with 10:1 pistons, .050" overbore, SSX stage 3+ hi-po power pack with sheetmetal manifold. that alone should make around 325 rwhp. once i get that i am getting a twin-turbo kit with either two Garrett GT30BB ball bearing turbos or two Caterpillar T6RAS Ball Bearing turbos. put about 16 PSI through two one core micro-coolers then through a 4-core twin entry air-to-air after cooler should put me well over 550 rwhp and 600 ft-lbs of torque. of course i would need supporting mods like suspension, big-*** tires, chassis reinforcement, built 8.8 rear-end, and a 3 inch exhaust.
Old Sep 17, 2005 | 12:25 AM
4600cc's Avatar
4600cc
I ♥ Acer
If you looking for ECM and ignition to control your modded motor check out www.megasquirt.info and www.picasso.org .
JonnyBlazeGT
Nov 3, 2015 01:10 AM
Jskeezy84
Sep 8, 2015 01:40 AM
Boostaddict
Lethal Performance
Aug 13, 2015 01:57 PM
tyco
Feb 14, 2004 10:24 PM
tyco
Dec 7, 2003 02:22 AM
