A/C vent setting selection problem. Need help.
Old Feb 6, 2012 | 11:47 AM
Dmonty420's Avatar
Dmonty420
Default A/C vent setting selection problem. Need help.
I have a 98 stang and the A/C will only blow thru the top defrost vent regardless of what setting I have it on. Any guesses or knowledge to what could be causing this?
Thanks
Old Feb 7, 2012 | 10:17 AM
AzPete's Avatar
AzPete
Vac. leak or defective switch. Ford has them default to defrost for safety if the system fails in the winter.
Old Feb 7, 2012 | 05:01 PM
ttocs's Avatar
ttocs
go to the firewall on the passenger side and locate the where the coolant lines go through. There in that cluster of crap going in/out is a single vac line that goes across the back of the firewall to the vac tree on the drivers side. It will more then likely be dangling down and just need a small connector or extended an inch or two. That vac line goes to the blend door to control it.
Old Feb 8, 2012 | 05:41 AM
petrock's Avatar
petrock
The line ttocs is taking about is a thin plastic tube. They tend to get brittle and break as the car ages. If it is broken, you can splice the two ends together with a rubber hose with an inner diameter a little smaller then the plastic tube (to make a good seal). I got one from my local autoparts store when the tube broke on my wifey's '98 mustang.
Old Feb 8, 2012 | 10:20 AM
Dmonty420's Avatar
Dmonty420
Hell yea! Thanks! I'm at work right now but I'll under the dash as soon as I get off!
mtgldr
Feb 3, 2024 09:00 PM
carid
Jul 8, 2016 09:55 AM
movielover40
Sep 15, 2015 10:37 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
tmdm
Sep 4, 2015 06:45 PM
