Fuel Pump? which one?
Old Sep 21, 2005 | 11:51 PM
babyvamp101's Avatar
babyvamp101
Default Fuel Pump? which one?
255LPH
155GPH
190LPH
Car is Stock and the fuel pupm went out on my tonight sitting at the gas station...So therefor I had to have it towed. Any sudgestions?
Old Sep 22, 2005 | 03:26 PM
99saleen351r's Avatar
99saleen351r
Default RE: Fuel Pump? which one?
Seeing that its stock I would just use a 155 cause you dont really need any more than that ,but if you plan on some mods in the future go with the 255 because you might need the extra pressure
Old Jul 3, 2006 | 04:40 PM
C!ph3r's Avatar
C!ph3r
i dont like starting new threads when i don’t have to so i though i would reopen this one. I am in the same dilemma. I currently converting my 4cyl to a V8 and seeing i have to upgrade my fuel pump anyway, i wanted to get a bigger one. Will if cause any problems having a high output fuel pump on a stock motor? Stock with the exception of some bolt ons. I want to add a Kenne Bell SC at some point down the road. Suggestions?
I have the same question about injectors. I need new one and wanted to go ahead and get injectors that will support the SC but i don’t want to get them if i may cause any damage.
Thanks for the help.
Old Jul 3, 2006 | 06:20 PM
ShadowDrake's Avatar
ShadowDrake
They won't, just watch the tune... you'll need to keep an eye on the fuel pressure, which will be taken care of when you get it tuned. After you add the blower, all you'll need to do is get it re-tuned.
Old Jul 3, 2006 | 07:01 PM
C!ph3r's Avatar
C!ph3r
couldnt i just use an aftermarket fuel pressure regulator to drop the pressure?
Old Jul 3, 2006 | 07:12 PM
ShadowDrake
Yeah... what year are we talking here? An aftermarket regulator would work great... when it's getting tuned, you'll have to adjust the pressure to perfect your A/F ratio. If it can be controlled from the ECU, even better (variable voltage to the fuel pump to give correct pressure).
Old Jul 3, 2006 | 07:56 PM
C!ph3r's Avatar
C!ph3r
my car is an 87 4cyl. i will be putting in a new roller 5.0 using the upper and lower intake, fuel rails, injector harness, and so on from an 88 5.0. I would like to use a harness from an 89 so i can get a MAF ecu and harness with out having to rewire my dash to work with the engine harness.
Old Jul 4, 2006 | 06:44 PM
blackbetty01's Avatar
blackbetty01
Well I have a practically new Walbro 255 pump. I installed it and when I went and got my car tuned the next day I found out it wouldnt give me enough fuel. It should be fine for you since you have a return style fuel system. Make a reasonable offer.
Old Jul 5, 2006 | 07:23 PM
gspfunk's Avatar
gspfunk
You can also check out jdsperformance.com
they have good prices on Walbro fuel pumps as well as other things...
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
Sixx
Oct 5, 2015 07:36 PM
mrappe
Sep 26, 2015 10:16 AM
