How do these work?
Old Sep 22, 2005 | 10:51 PM
Dan9687's Avatar
Dan9687
Default How do these work?
Ok, Ive seen on SOHC engine like a stock stang GT and V6 where the rocker arms are on the heads and with the springs below them and the rods connected to the rocker arms...but I want to know where the other end of the rods go or connect too? And also what do they do? What are they there for? Please explain in lamens terms...lol. Thanks.
Old Sep 22, 2005 | 11:21 PM
Chopper's Avatar
Chopper
Default RE: How do these work?
There are no pushrods in a Single OverHead Cam(SOHC)=4.6 engine.There are lifters,or lash adjusters,though.In an OverHead Valve(OHV)=5.0 engine the pushrods go down through the head to the lifters that ride on the cam lobes themselves.The cam is in the valley between the cylinder banks and under the intake manifold.The SOHC engine has a camshaft for each head.This cam rides directly on the rocker arm and opens the valve by pushing down on the rocker arm.This causes the valve to open.Valve lash,or clearance,is maintained by an oil pressurized cylinder called a lifter.There is a piston inside the lifter that keeps the rocker in contact with the camshaft.The lifter is on one side of the camshaft and the valve is on the other.
Old Sep 22, 2005 | 11:28 PM
Dan9687's Avatar
Dan9687
ORIGINAL: Chopper
Old Sep 22, 2005 | 11:31 PM
Dan9687's Avatar
Dan9687
oops....Im kinda new to the quote stuff. But from what you said above about the SOHC I dont understand? How is there a cam per head when SOHC means SINGLE over head cam? If there were 1 cam per head wouldnt that be called DOHC for DOUBLE over head cam???? Please explain
Old Sep 22, 2005 | 11:33 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
DOHC would have two cams per head. SOHC has one per head.
Old Sep 22, 2005 | 11:51 PM
Dan9687's Avatar
Dan9687
Then what the hell is the name of the engine with ONE cam only in it???
Old Sep 23, 2005 | 12:22 AM
JD1969's Avatar
JD1969
People call them all kinds of things, like, push rod motors, cam in block etc. there really is not a need for a special name, single cam motors are the oldest style engine around. That does not mean however that they a obsolite technolgy, the most powerfull engines in the world are single cam engines (NHRA Top Fuel), and plenty of street cars, make alot of power with them.
Old Sep 23, 2005 | 12:36 AM
Dan9687's Avatar
Dan9687
So whats my stock 99' V6 stang and stock GT stangs and that???
Old Sep 23, 2005 | 12:58 AM
JD1969's Avatar
JD1969
Your car is a pushrod motor. 96 and up 4.6 GT's had either a SOHC in the GT or a DOHC in the Cobras. 95 and older 5.0's were pushrod.
Old Sep 23, 2005 | 05:33 AM
03YellowPony's Avatar
03YellowPony
ORIGINAL: Dan9687
It's called a push rod engine or OHV engine.
Over
Head
Valve
Or a 4 banger, or straight 6
