what cam
Old Oct 1, 2005 | 06:50 AM
3stangs's Avatar
3stangs
Default what cam
if i put a set of gt40x heads on a stock 94 gt what cam should i go with? And with a the heads and cam swap will the stock injecters be ok to keep? Will I need to get push rods or will the original work? I'm just worried that I'll push my budget and I'll end up needing some part that I don't have money left fore.
Old Oct 1, 2005 | 10:16 AM
Sidewayz6.0's Avatar
Sidewayz6.0
Default RE: what cam
Let's start out with...Why the GT40p heads? The stock pushrods and injectors will work, with the stock valves, but you'll have to buy special headers to fit the P heads.
However, I have a solution to this problem. I have a set of GT40 heads and a Cobra/Explorer intake. Upper and lower that will fit nicely on there for you. Then you can use any Mustang headers, or even the stock manifolds. (It would be a waste, but they'll work)
Let me know if you want them.
Old Oct 1, 2005 | 05:39 PM
3stangs's Avatar
3stangs
not gt40p ------but gt40x and thanks for the offer i'll think it over.
Old Oct 1, 2005 | 09:27 PM
Sidewayz6.0
You know, I had my head up my ***. You were talking about the Aluminum "Turbo Swirl" heads right? Sorry...It was early.
Old Oct 1, 2005 | 09:35 PM
grabbem88's Avatar
grabbem88
i would spend the 90 bucks on some hardened pushrods...with 1.60/1.90 valves call comp cams
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
