supercharger help again....
Old Oct 2, 2005 | 09:47 PM
stangnsnow's Avatar
stangnsnow
Default supercharger help again....
i jsut installed a powerdyne supercharger and at about 3000rpm the car studders what do you guys think this could be? i hooked up an FMU and it is still doin it..thanks STeve
Old Oct 3, 2005 | 04:37 PM
fordguy17's Avatar
fordguy17
Default RE: supercharger help again....
probably not enough fuel. (stop driving it!!!)
what car, what engine, what's the rest of your setup?
Old Oct 4, 2005 | 12:16 PM
stangnsnow's Avatar
stangnsnow
it is only putting out 5psi so it really shouldnt need a different fuel pump or anything... 19 lbs injectors should be more than enough
Old Oct 5, 2005 | 03:51 PM
fordguy17's Avatar
fordguy17
you should get a bigger fuel pump. 24 lb injectors wouldn't hurt either.
Old Oct 6, 2005 | 07:32 AM
92BOOSTED's Avatar
92BOOSTED
Did you buy this kit new or used?
The new kit comes with a bigger fuel pump so what do you think??? We need to know what your combination is really.
Know matter what though, you should use at least 24# injectors even for a stock motor with and a minimum of a 155lph pump.
Type in what you have for the best possible advice.
Rye
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Gene K
Oct 21, 2015 11:37 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
col2560
Sep 25, 2015 08:59 PM
