Harmonic balancer wobble
My car is now a week old to me today. I've done a full tuneup through the week including water pump and several other things not in the tune up list. While doing the plugs and wires today I noticed the harmonic balancer wobbles about 1mm of deflection or so. I have no way to know how long it has been doing it, but the engine is not leaking anything at all, no noises, and runs like a top so I know I have caught it early before it can rattle my crank bearings.
My question is how much it will bother it if I can't get a new balancer here before two weeks or so. Any risk of causing any noticeable wear on the crank bearings if it is taken care of within the month?
Yes, it is bad. Make sure that it is just the balancer that is wobbling and not the crankshaft itself. If its the shaft, then you’ve got bigger problems. Eyeball the center bolt on the balancer and see if it is moving. If it is, then the crank is wobbling.
Good luck...
Good luck...
If you could see (with super-vision) the front end of the crank wobbling don't even worry about the bearings, they are gone.
Better test of the balancer woild be to take it off, chuck it in an engine lathe and use a dial indicator to see how bad it really is.
Nothing you can do about repairing the thing anyway......
Good luck...
KingRando
Oct 2, 2015 08:06 AM
jessicarabbit
Sep 25, 2015 12:41 PM
LivingInThePast
Sep 16, 2015 12:20 PM
Sep 8, 2015 11:50 AM
