302 build questions
Old Aug 3, 2013 | 09:46 PM
bigwitty's Avatar
bigwitty
Default 302 build questions
i just bought a 302 block today and plan on building something with 300-350 hp couple questions its a 86 block already had flat top pistons and when a say flat i mean flat no valve releifs what heads would go good with these? can i get what i want with e7 heads with a good port and valve job and i am putting this into a 95 is there any electrical connectors in the block? if so was gonna carburate and ditch fuel injection any ideas or suggestions
Old Aug 4, 2013 | 09:03 PM
tinman's Avatar
tinman
There are no electrical connections to the block casting.
If I remember right the '86 is a 1 year only deal with the flat-top pistons, I also believe it has a positive deck height meaning that the tops of the pistons at TDC will be above the deck.
No real reason to go with a carb as I see it......
Galactic
Apr 29, 2019 02:56 PM
the5
Sep 19, 2015 06:13 PM
04stangman
Sep 17, 2015 01:45 PM
jaiidutch
Sep 14, 2015 10:29 AM
ryland
Sep 13, 2015 12:35 PM
