Random missfire problem
Old Aug 15, 2013 | 02:52 PM
bootstrap_bill15's Avatar
bootstrap_bill15
Default Random missfire problem
Lately i have been having problems with random missfires. I will be driving and the car will start missfiring, bog down quite a bit and the check engine light will turn on. It never lasts for more than a minute or so and the car will never actually die. Once it stops missfiring it drives perfectly fine. It often happens more than once a day, sometimes mutiple times. I never have had this issue until my underdrive pulley was put on, so im wondering if it is a small timing issue. I plugged my tuner in to check the error codes and it reads random missfires. I replaced plugs, wires and did a complete tune up to cover all the minor basis and the problem continues. All i can come up with is maybe the guy that installed my underdrive pulley messed up the timiming slightly. If anyone has had this problem or can shed some light on this it would be greatly appreciated.
Oh and its on a 07 gt
Old Aug 15, 2013 | 03:05 PM
Derf00's Avatar
Derf00
Gentleman's Relish
on a 07Gt you will not have 'wires' Aside from plugs there's isn't really much else to change for a 'tune up'. What all did you change?
Misfire hiccups like this can be caused by a bad/loose Camshaft position sensor. You have two. Each one is located towards the front of the engine on top of the valve cover.
http://smg.photobucket.com/user/taco..._4487.jpg.html
Check the sensor is in place not wobbling around and check the wire harness and wiring for crimps, frays, or looseness.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
