Do I need a torque wrench?
Old Oct 10, 2005 | 03:13 PM
nyjets10's Avatar
nyjets10
Default Do I need a torque wrench?
The instructions for my SLP LM II's say i need to torque down the flanges on the h-pipe to 26 foot-pounds. I'm certainly not buying a torque wrench and don't feel like renting one for tightening the 4 bolts or whatever it is on those flanges. Can I just tighten it with a regular wrench or is it neccesary to torque it down? Also, can anyone estimate how tight 26 foot-pounds is?
Thanks
Old Oct 10, 2005 | 03:18 PM
03YellowPony's Avatar
03YellowPony
Default RE: Do I need a torque wrench?
No you don't "need" a torque wrench. Just tighten them up good. and try to keep it even. And yes, I could est 26ft/lbs of torque, but not over the internet. That's almost impossible. I would also recommend re-torqueing the bolts after you run it.
Old Oct 10, 2005 | 04:59 PM
Fallstar01's Avatar
Fallstar01
Toque wrench from home-depot (husky) isn't bad. Much cheaper than snap-on, even way cheaper than craftsman. It's a worthwhile investment if you plan to work on cars alot.
Old Oct 10, 2005 | 05:15 PM
T1H5ON's Avatar
T1H5ON
i just cranked down like a **** on all the bolts when i put my catback on
Old Oct 10, 2005 | 05:21 PM
Dan04COBRA's Avatar
Dan04COBRA
I think I paid like 15 bucks for a torque wrench?
It's good for a lot of things, especially when putting wheels on. Doesn't take much to wreck some chrome wheels by overtightening.
Old Oct 10, 2005 | 05:22 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
if you want to do it right, use the torque wrench. that's why torque specs exist. over tightening can ruin things just as undertightening can.
Old Oct 10, 2005 | 05:24 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: nyjets10
Thanks
Is a torque wrench 'required' no, but it's a good idea. Especially when you have heat involved. If the bolts are too tight or loose, you may get warping which will cause an exhaust leak. Some parts it's a necessity (heads/manifolds/suspension) because one bolt being too loose over another and it could cause some damage or just have the same problem you had before (manifold could get a gasket leak)
There's also the possibility of overtightening which could cause a crack. You can wing it on a the exhaust pipes (not the manifold). If you overtighten you may bust-a-nut or if you undertighten, it may come loose and cause a leak. $25 is not a bad investment for a cheap torque wrench at Autozone or Pep Boys. Why take shortcuts when you obviously want to make your car better?
Old Oct 10, 2005 | 06:21 PM
blueangelfightr's Avatar
blueangelfightr
ORIGINAL: Derf00
ORIGINAL: nyjets10
Thanks
Wise man. I couldn't have said it better myself.
Old Oct 10, 2005 | 11:39 PM
DaGGer's Avatar
DaGGer
if you could tell how much weight you are putting on the wrench them you can do the calculations yourself and be one kick *** jimmy rigging mother ****er.
Old Oct 10, 2005 | 11:44 PM
Moparman87's Avatar
Moparman87
I just got one for $10 at canadian tire
