Unknown Fuel Problem
Old Nov 26, 2013 | 03:37 PM
TaylorLetsGo's Avatar
TaylorLetsGo
Default Unknown Fuel Problem
2001 Mustang 3.8L
I drove it on Tuesday of last week, on Wednesday it would not work. The engine fired correctly but would not crank. I thought it might be a fuel pump issue. Using some starting fluid I was able to get it to crank for about 30 sec. I then proceeded to test if the fuel pump was getting power, it was. I removed the fuel pump and tested it. The pump works fine. I reinstalled the fuel pump and things got weird. The car still didn't crank but when the key was turned to the on position the a/c fan came. After some research I found that the CCRM controls the power to both the fuel pump and a/c fan. I changed out the CCRM and there was no change. The fan is still coming on when the key is in the on position and the car doesn't crank.
Also the inertia switch is in the correct position.
Any suggestions would be appreciated.
Old Nov 26, 2013 | 07:42 PM
petrock's Avatar
petrock
I’m confused. If it doesn’t crank (motor doesn’t spin) then how did it run when you put starter fluid in the intake? Maybe you have your terms mixed up. “No Crank” means that the motor doesn’t spin when you turn the key. "No Start” means the motor spins but doesn’t keep spinning when you let go of the key. I think you’re talking about a No Start issue, not a No Crank issue.
It sounds like a fuel issue. Rent a fuel pressure gauge from your local auto parts store and test that you have fuel pressure at the fuel rail. If you have pressure, then test for spark. If you don’t have pressure check that the fuel pump is turning on when you try t start the car. If not, check the flu pump relay to make sure it is clicking on when you try to start the car. If it does, then make sure there is power in the whole for pin 30 of the fuel pump relay. If it does, then work your way back to the fuel pump and make sure you have _both_ power & ground. You need both. Once you’ve done all that and still haven’t figured out the problem, post back up into this thread and we’ll see if there are any other tests you can do…
Good luck...
Old Nov 27, 2013 | 08:08 AM
TaylorLetsGo
Sorry about the confusion...it has always cranked but never started. Thanks for the tips. I have found conflicting reports on the "fuel pump relay." Are you referring to the unit located in the trunk before the inertia switch?
Thanks again.
Old Nov 28, 2013 | 03:17 AM
petrock's Avatar
petrock
The fuel pump relay is the little black box in the fuse box under the hood.
Old Dec 16, 2013 | 07:24 PM
alfred9744's Avatar
alfred9744
my car has been doing something similar after sitting for a couple of days. think it might be the fuel pressue transducer.
StalkerGT
Sep 25, 2015 02:41 PM
zanemoseley
Sep 6, 2015 12:58 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
5.0 kevo
Sep 3, 2015 06:24 PM
SYNY5TER
Sep 2, 2015 01:35 AM
