Sponsored by:
Sponsored by: DashLynx
Couple of Q's
Old 10-12-2005, 04:25 PM
tightdogal
tightdogal's Avatar
Default Couple of Q's
Ok I just got my transmission fluid serviced...it hasnt been serviced in a while. They said the fluid was getting burned out so I prety much needed to get it...ive heard if the transmission is serviced and hasnt been servied in a while its not good..so did i do a good thing or bad thing? also, they said i needed to get my pcv valve replaced...whats that?(im bad when it comes to technical stuff)
thanks
tightdogal is offline
Old 10-12-2005, 05:44 PM
03YellowPony
03YellowPony's Avatar
Default RE: Couple of Q's
ORIGINAL: tightdogal
thanks
How many miles between the tranny service. The rule of thumb is more than 75k and don't touch it.
03YellowPony is offline
Old 10-12-2005, 07:06 PM
Tim37
Tim37's Avatar
when you put the new fluid in it won't have all the nasty little particals in it. the new fluild will sometimes allow the tranny to slip. a pcv valve allows the intake to pull a slight vacume on your crank case keeping presure form building up and forcing oil out the seals.
Tim37 is offline
Old 10-12-2005, 07:34 PM
tightdogal
tightdogal's Avatar
Well since ive had the car at 90,000, the transmission was never serviced...ill give a more definite answer later on,.....and is the pcv valve critical? or can i wait to replace it in a few months (college sucks ur money more than monica lewinski suckin off bill clinton)
Old 10-12-2005, 07:59 PM
03YellowPony
Do the PCV NOW! It's only like 10 bucks. If enough pressure builds in the crank case, you will blow rings.
Well, you could spray it with Carb cleaner. Shake it some, you should hear something rattling inside. If not...REPLACE IT!
Old 10-12-2005, 08:05 PM
tightdogal
tightdogal's Avatar
ok...good to know...ill look those up today...u know what store i can find them? (lol i need that guy who has the link to the sites where i can order stuff from) and also i just talked to the previous owner of my car, the transmission was serviced once before 75,000, like at around 50,000 miles or so...is that still not good?
Old 10-12-2005, 08:33 PM
Tim37
Tim37's Avatar
any parts store will have them some will even help ya put it in.
Tim37 is offline
lovesilver
Members Mustangs
05-09-2019 09:18 PM
Thunderball
15
11-22-2015 11:49 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
Matt's 95 Stang
10-05-2015 07:16 AM
logan409
09-26-2015 07:43 PM
Quick Reply: Couple of Q's
