Need help with my 2.3!!! Running issues
Old Mar 8, 2014 | 07:12 PM
jdm009's Avatar
jdm009
So I put new spark plugs, distributor cap, new wires and rotor and the thing still sounds really rough and the motor is shaking a lot I'm stumped!
Old Mar 10, 2014 | 10:26 AM
jdm009's Avatar
jdm009
Originally Posted by Chromeshadow
Vacuums leak are easy to check for, get a can of starting fluid and spay it near the leak. The engine will speed up when you are near the leak. You should start by visually checking all of the small rubber hoses.
You may have a leak in the intake manifold where it bolts to the engine. Be careful with starting fluid, it's extremely flameable and the fumes can put you to sleep. I'd look for something near 3 and 4.
Do you have a clue what's wrong because I'm stumped! Would it be my coil?
Old Mar 10, 2014 | 11:07 AM
Chromeshadow's Avatar
Chromeshadow
There are a couple of ways to check spark. one of the easiest it to pull one plug, connect the plug wire and ground the plug, then crank the engine. You should have a nice blue spark. You can use the same plug on each plug wire.
I usually just us a timing light with a clamp sensor, and clamp it one each wire one at a time.
Btw, I usually wear gloves when holding a spark plug,getting shocked is another way to test the spark.
Old Mar 10, 2014 | 11:56 PM
jdm009's Avatar
jdm009
Could it be my timing? Could my timing jump and it not running right
Old Mar 11, 2014 | 07:31 AM
88 orangepeel notch's Avatar
88 orangepeel notch
Yes it could be off, but that would mean the timing chain skipped a gear, which isn't that common. Check your timing, and take note on how steady the mark stays in one area. If its jumping around by 5°or10° both ways at idle, I'd think you'd may need a new chain and gears. How many miles are on this car? Are you sure you have the wires running to the correct cylinders?
EDIT: I'm thinking 302, does a 2.3 even have a chain, or does it have a belt?
Old Mar 11, 2014 | 10:01 AM
jdm009's Avatar
jdm009
It has a belt and the engine has 270 kms
Old Mar 11, 2014 | 04:53 PM
jdm009's Avatar
jdm009
[QUOTE=88 orangepeel notch;8360499]Yes it could be off, but that would mean the timing chain skipped a gear, which isn't that common. Check your timing, and take note on how steady the mark stays in one area. If its jumping around by 5°or10° both ways at idle, I'd think you'd may need a new chain and gears. How many miles are on this car? Are you sure you have the wires running to the correct cylinders?
EDIT: I'm thinking 302, does a 2.3 even have a chain, or does it have a belt?[
Old Mar 12, 2014 | 06:52 AM
88 orangepeel notch
I doubt timing jumped, but you may want to double check for piece of mind. And your sure the wires are routed correctly? I'm running out of ideas too.
A engine only needs three things to run, air, fuel, and spark. If it's spitting/ studdering, I'd think it's either fuel or a spark issue.
Old Mar 12, 2014 | 07:08 AM
jdm009's Avatar
jdm009
If it's fuel related then how can I check thst
Old Mar 13, 2014 | 07:21 AM
88 orangepeel notch
Well I reread this thread from the start, and your car was running good then drops power and is now running rough, if at all. 2 of the 4 plugs were black, meaning its running way rich on those 2 cylinders or your rings or valve guides are worn and burning oil. You said it doesn't blow any blue smoke so I'm thinking way rich in 2 cylinders. But your car has indirect fuel injection, meaning all cylinders get the same air/fuel ratio. Which then leads me to an incomplete burn in those 2 cylinders. But you replaced plugs, wires, cap and rotor. ????
Have you replaced the distributor? I'm not familiar with 2.3's, can you even pull codes on those? Being fuel injected, there should be codes stored somewhere.
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
2007StangV6
Jan 28, 2016 06:09 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
Emblazoned
Sep 3, 2015 10:45 PM
