2.3L must go
Old Oct 13, 2005 | 01:21 AM
Velvet Leopard's Avatar
Velvet Leopard
Default 2.3L must go
Hewwo, guys. I have a 1993 LX Notchback with the stock 2.3L 4 cylinder. I like this engine okee, but I want to pull it out and add a much more powerful (torque-wise) mill. I was thinking of adding in a 1972 351W pulled from a stout Galaxy. I have this engine and the mechanic had very recently rebiult it with new parts and blueprinted it with 1968 (or 1969 can't remember) stats. I here this mill has awesome torque numbers. Would this be an adequat mill or can I go better? Also, just to be curious and see what all I have to work with, what is the biggest (in physical dimensions) engine I can fit into my little PonyCat without doing awesomely major cutting and welding to the front end? I thank your time. =^.^=
Old Oct 13, 2005 | 03:22 AM
DR8907's Avatar
DR8907
Default RE: 2.3L must go
A 351 Windsor is more than adequate. Some people here have 408s... so you could always go bigger - but the 351W is a good choice. Also try posting in the 5.0 section.
Old Oct 13, 2005 | 01:59 PM
Tim37's Avatar
Tim37
they make kits to put 460's in foxes but that 351 will do ya very nice. like Velvet Leopard said if ya want you can stroke it to a 408. the 72 block is a good block stronger than the latemodel 351's i am guessing it has 69 heads some consider them to be the best production windsor heads. i have seen some stout cars with similar set ups to what you are planning.
Old Oct 14, 2005 | 10:35 PM
Velvet Leopard
Sweet. I found out the engine is the stock 351W from a 1971 Ford Gran Tourino. Not sure what the block number and head numbers are though. I do believe they are '69 heads though. It has a 2-barrel carb intake minus the carb.I may stroke it later, but now I just want tit to run in the car.
jlopret
2.3L Eco-Boost Tech
Nov 19, 2015 10:32 AM
ShaneB26154
Aug 28, 2015 04:47 PM
Pyre
Dec 23, 2005 01:36 AM
tommyboy1989
Jun 21, 2004 02:21 PM
