wheel bearing change HELP!!!
Old Oct 13, 2005 | 05:51 PM
ChrisParis's Avatar
ChrisParis
Default wheel bearing change HELP!!!
I just bought a 1987 Mustang LX about a week and a half ago..... The car originaly came out with a 4 banger. But, about 70,000 miles ago someone done a 5.0 swap with a T5 transmision and 3.73 gears in a 8.8 inch rear end. My front wheel bearings are going out and I am not sure if they where upgraded or not????? The parts store is telling be that the LX and the GT wheel bearings are a dif. part number as well as the LX with the 4 banger is a dif. part number then the LX with a 5.0????? This is where I need the help...... how do I know what bearings that I need? What is the difference in the wheel bearings on the 3 dif. cars?
Old Oct 13, 2005 | 11:26 PM
DaGGer's Avatar
DaGGer
Default RE: wheel bearing change HELP!!!
ok well first you need to know if the person did a front brake swap, did they take and put the 5.0 brakes on your car if they did then you need a 5.0 wheel bearing because the 2.3's used different spindles. So find out if the brakes are from the 5.0 or the 2.3 and then get the ones according to those.
Old Oct 14, 2005 | 12:13 AM
89stanglx's Avatar
89stanglx
buy all 3 types and return the two you dont need
Old Oct 14, 2005 | 05:18 AM
ChrisParis's Avatar
ChrisParis
Can I buy a LX 5.0 spindle and upgrade the bearings, rotors, and calapers to what came on a LX 5.0?? Or will they not bolt up? If I replace what is already there will I keep having trouble due to the dif. in what is suposed to be with the 5.0 motor?
Old Oct 14, 2005 | 07:10 AM
03YellowPony's Avatar
03YellowPony
Take the old bearing out. There should be a part number stamped in it. If not, take the bearing to the Parts store, and have them match it. I used to match bearings a lot. It's not rocket science. Good luck!
Tivo304
Aug 28, 2023 12:19 PM
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
whatsup62
Oct 16, 2015 03:07 PM
97SN95GT
Sep 13, 2015 09:45 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
