Too much air?
Old Aug 17, 2014 | 09:30 AM
CarNoobLovingIt's Avatar
CarNoobLovingIt
Default Too much air?
Im currently running a trick flow 75mm TB and Plenum
I've read that a 75mm TB/plenum combo or higher is too much air for a NA engine. Is that because the stock fuel injectors wouldn't be able to supply enough fuel to compensate? And if that is the case would upgrading your manifold and injectors to say 30 lbs or higher balance it out and produce more power?
Old Aug 17, 2014 | 10:58 AM
yourmom6990's Avatar
yourmom6990
have you tuned it to compensate for the increase of air?
Old Aug 17, 2014 | 11:26 AM
CarNoobLovingIt
Yeah I have thr SCT tuner. I was just wondering if upgrading my injectors would help if I decided to get like a 90 mm (hypothetically speaking)
Old Aug 17, 2014 | 07:30 PM
yourmom6990
You're not going to see much difference on a N/A engine. It's not necessary with just a t/b/plenum. Unless you have internal work such as heads/cams/intake I wouldn't worry about injectors at this point. The stock injectors should provide properly with a few simple bolt ons. If you haven't already, I would suggest doing exhaust work to let her exhale.
Old Aug 17, 2014 | 07:34 PM
CarNoobLovingIt
I've got a flowmaster catback and off road x pipe. Right now I'm trying to decide if I want long tube and a shorty x pipe or just get regular headers.
Old Aug 17, 2014 | 08:19 PM
yourmom6990
The shorty headers would cost a lot less but the long tubes with an o/r x would make that v8 obnoxiously loud.
Check out this link: http://www.americanmuscle.com/best-f...g-headers.html
daltron
Apr 28, 2016 08:10 PM
bradleyb
Nov 27, 2015 07:50 PM
Dokilar
15
Oct 16, 2015 08:13 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
