Turbo Coupe Rear
Old Oct 19, 2005 | 05:57 PM
KillSwitchNY's Avatar
KillSwitchNY
Default Turbo Coupe Rear
i am thinking about buying an 88 turbo coupe tbird so i can swap rears with my 88 GT to get the disc rear.
how much work is involved with removing/installing the rears. will i need any other parts besides what the turbo coupe has to bolt everything up to my mustang?
do i need a new proportioning valve and brake lines or what? also im going to convert to 5 lug while i have the rear out.
also does anyone know if the turbocoupe rotors are the same size as a 5 lug sn95 rotor? im hoping i can just swap axles and rotors and be done
Old Oct 19, 2005 | 06:15 PM
C/Note's Avatar
C/Note
I ♥ Acer
Default RE: Turbo Coupe Rear
HUM I DO HAVE 1 5 lug axle out of ranger.the short one .you will need diff mas/cylinder turbo coupe one might work ..???
Old Oct 19, 2005 | 07:33 PM
Tim37's Avatar
Tim37
i would think you could just swap rearsends proportioning and mastercylinder and be done with it.
Old Oct 19, 2005 | 10:17 PM
DaGGer's Avatar
DaGGer
the rear end will fit right in there without any problems but it will be like 1" wider on both sides i believe, also you need to get a portpoting valve and the master cylinder from the turbo coupe, cobra, or some other vehicales i belive.
Old Oct 19, 2005 | 10:48 PM
vfast's Avatar
vfast
I ♥ Acer
actualy it's .75" inch wider each side..this can be fixed with a more offset rim
Old Oct 20, 2005 | 02:34 AM
KillSwitchNY
oh well im will be using stock 98 GT wheels, 17x8 split 5 spokes with 245 45 17 tires..... hopefully theyl stay in there....
oh one more question, i have a 98 GT setup for the front... spindles calipers brake lines and rotors... will the turbo coupe proportioning valve work with that setup also?
cuz it will be a mixed up setup.. 98gt front conversion and turbocoupe rear disc
Old Oct 21, 2005 | 12:30 AM
dirkpitt289's Avatar
dirkpitt289
Killswitch
did you end up buying the turbo coupe? Is the engine/ turbo for sale?
thanks
Dirkpitt289
Old Oct 21, 2005 | 12:51 AM
KillSwitchNY
not yet if i do i will be swapping the rear from my car to that 1 and probably selling the whole car. ill let you know if anything happens.
Luke9222
Oct 22, 2015 11:55 PM
mmarsh3014
Wheels & Tires
Oct 20, 2015 09:08 AM
uberstang1
Sep 20, 2015 06:42 PM
Sep 1, 2015 08:16 PM
