Rear brake pistons seized?
Old Mar 10, 2016 | 09:17 AM
dmastinsc's Avatar
dmastinsc
Default Rear brake pistons seized?
Just got my 2012 Mustang and am prepping for my first track day. I purchased some HP Plus pads and installing the fronts was a breeze.
When I moved to the rear, first, the caliper took a TON of forced to slide off the pads. When I put in my disc pad spreader to compress the piston, the piston would not recess back into the caliper even after a TON of pressure. I even tried loosening the bleed valve and the caliper still would not budge. I tried hard enough that my disc pad spreader even broke.
This happened on both sides of the rear, as well.
Can anyone tell me if this may be normal and perhaps I'm missing something???
Old Mar 10, 2016 | 10:28 AM
JimC's Avatar
Super Moderator
The rear doesn't push in. You need the tool that turns it. They "screw" back into place, unlike the front pistons
Old Mar 10, 2016 | 10:50 AM
Z28KLR's Avatar
Z28KLR
^ Yup. Go to Autozone or wherever, "rent" their brake caliper tool and the piston turns clockwise while applying pressure to push it back into the bore. Don't bother with that stupid $5 square thing that attaches to your ratchet, it is completely useless.
Old Mar 10, 2016 | 12:11 PM
dmastinsc's Avatar
dmastinsc
Cool...I was just missing something. Thanks for the quick answer to my problem!!!
Old Mar 10, 2016 | 01:39 PM
jwog666's Avatar
jwog666
it should look something like this
dkelban
Forum Issues and Feedback
Mar 10, 2016 04:38 PM
Skylane765
Feb 5, 2016 06:52 PM
Mark12gt
Oklahoma Regional Chapter
Jan 26, 2016 08:27 PM
cglavan
Jan 23, 2016 08:07 AM
