Rotor Question
Old Oct 25, 2005 | 10:10 AM
Smooth_J's Avatar
Smooth_J
Default Rotor Question
I need to replace my breaks soon, so I figured to replace the rotors as well.
What is better... cross-drilled, slotted, or both slotted and cross-drilled rotors?
Old Oct 25, 2005 | 01:15 PM
waxyourboard's Avatar
waxyourboard
Default RE: Rotor Question
Cross drilled help cool your rotors, increasing your braking by keeping the heat down and letting gases escape... but may weaken them so they crack and also reduce braking surface area. Slotted rotors basically clean the surface of the pad every rotation with the slots and let built up gasses escape, but they lessen the life of your brake pads by actually slicing off tiny amounts every time your brake
Cross drilling and slotting also decreases the surface area of the rotor (85-93% remains for drilled, and around 93-96% for slotted)
Old Oct 25, 2005 | 01:58 PM
Tim37's Avatar
Tim37
in short if you what best possible breaking ablitly both slotted and drilled.
Old Oct 25, 2005 | 02:51 PM
ShadowDrake's Avatar
ShadowDrake
Unless you're doing racing (and not the 1/4 mile variety, nor street) getting slotted or drilled rotors is mostly an appearance thing. Getting slotted and drilled rotors for a street-driven only car would be like buying a catback for the horsepower gains.
Old Oct 25, 2005 | 02:57 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
it's not worth paying extra over oem for rotors which are easier to crack and warp. just go with stock rotors. you're not racing down a mountain or anything weird, right?
Old Nov 11, 2005 | 11:00 PM
shane361's Avatar
shane361
Actually..if your normal street driver get the slotted/cross drilled. If your track then only slotted-Shane
Old Nov 11, 2005 | 11:18 PM
mkspeed26's Avatar
mkspeed26
i would only get slotted, drilling makes them very prone to cracking
GimpyHSHS
19
Dec 19, 2023 01:12 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
UrS4
Sep 30, 2015 10:13 AM
treesloth
Sep 28, 2015 07:03 AM
