Wheel Spacers?
Old Oct 25, 2005 | 06:31 PM
Jubin1's Avatar
Jubin1
Default Wheel Spacers?
What are your all thoughts on wheel spacers? I think it would look cool to have my tires flush with the fenders and have a wider wheelbase, but why are they so damn expensive. I mean $143 - $200 for some metal discs? How hard could it be to fabricate a pair of your own?
Old Oct 25, 2005 | 06:52 PM
closer9's Avatar
closer9
Default RE: Wheel Spacers?
I had a set on mine for several months with no problems. Definately helped the looks... Only took them off, because I got wider wheels...
If you need a set I've got some hubcentric ones for sale now...
Old Oct 25, 2005 | 10:45 PM
Jubin1's Avatar
Jubin1
thanks but my wheels are 4 lug. right now drilling some holes in a 1" thick circle of plywood is sounding pretty economical any feedback on that? sounds crazy enough to work
Old Oct 25, 2005 | 10:53 PM
TattooTears's Avatar
TattooTears
I don't know about the wood thing, but in general it definitely has a better look with either spacers or a wider rim. Gives it a much better look from the back.
Old Oct 25, 2005 | 10:57 PM
Jubin1's Avatar
Jubin1
thats the side most people see right? maybe instead of wood, layers of sheet metal or a thick piece of tough plastic
Old Oct 26, 2005 | 01:37 AM
Lex8109's Avatar
Lex8109
ORIGINAL: Jubin1
If you ask me, using wood anywhere in your suspension is not a good idea. Wheelspacers def. improve the look a lot but I am waiting until I get my 18x10 in the back and see if I still want them then.
Old Oct 26, 2005 | 04:28 AM
TattooTears
ORIGINAL: Lex8109
ORIGINAL: Jubin1
Those 10" wheels should give you a very nice look in the back, I seriously doubt you will want spacers after putting those on your car.
Old Oct 26, 2005 | 11:22 AM
closer9's Avatar
closer9
ORIGINAL: Jubin1
DO NOT, DO NOT, DO NOT use wood or anything else. If you can't come up with the funds for a set you don't need them.
You might talk to a machine shop about making you a set, and setting the studs yourself, but you probably wouldn't save much if any... But just a few thousandths thicker on one side will give you a nasty wheel wobble, which will only lead to worse things...
Old Oct 26, 2005 | 01:58 PM
Jubin1's Avatar
Jubin1
thanks everyone, i now realized my stupidity. instead of buying some spacers for $150-200, i'll save it and put it towards some wider rims and tires. any idea how wide a rim you can fit in the back of a '90 GT without messing with the fender walls or anything
Old Oct 26, 2005 | 04:14 PM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
ORIGINAL: closer9
ORIGINAL: Jubin1
+1
