a/c won't switch off
Old Oct 26, 2005 | 12:18 PM
GaryS's Avatar
GaryS
Default a/c won't switch off
I turned the a/c on in my 97 3.8l to clear the mist off of the windows. Now, no matter what position the heater/ac/vent switch is in, I get defrost up to the winshield. I can control the temp and fan speed fine but not the a/c. As I said, it is stuck on a/c in the defrost position.
What type of control does the center dash switch use? Vacuum? Any troubleshooting ideas?
Old Oct 26, 2005 | 12:48 PM
66stilinprimr's Avatar
66stilinprimr
Default RE: a/c won't switch off
I would start by looking under your dash and looking for the fuse to the heater switch. I would pull that first and then to see if it's blown, and could be blown in the on position. If that doesn't work..i would get a technical manual...if you don't have one they sell them at pep boys for like 15 dollars....It's better to see if it's something you can fix then go spend money having someone else do it.
Old Oct 26, 2005 | 04:37 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: GaryS
What year Mustang? Is the A/C actually on or are the vents just stuck in one position? If it's just the vents, it could be the cable or vacuum line that controls the position of the vents got disconnected. If the A/C is also staying on then take a look at the A/C cutoff switch near the evaporator in the engine compartment.
Old Oct 26, 2005 | 11:44 PM
GaryS's Avatar
GaryS
My original post says it all - 97 Mustang w/ 3.8l engine. Yes, the a/c is stuck on and is blowing from the upper vent for the defroster. The a/c isn't acting as if it is really charged well because it took a while to clear my windshield of condensation. But that is difficult to really tell since it was about 40 degrees outside.
Can you elaborate on the control from the a/c/vent/heat switch on the dash? Is it vacuum operated or cable controlled? And what does the a/c cutoff switch look like? I am generally ok with a/c components but do not know what this looks like.
Old Oct 29, 2005 | 12:25 PM
GaryS's Avatar
GaryS
Default RE: a/c won't switch off - Part II
OK, checked out the system and the a/c is low but that isn't the problem. The system is stuck so that the air only blows out of the defroster vents. So it looks like I am going to tear the dash apart and see what the culprit is.
Can anyone who has been inside the dash tell me what lies behind the switch? Is the system controlled by a vacuum switch or by a cable?
Gary
97 3.8L
Old Oct 29, 2005 | 01:16 PM
bryanec's Avatar
bryanec
I had a 97 CV that done the same thing. Vacuum leak. Start your car ,roll down your windows, take a propane torch (do not light) and slowly run the gas along the lines until the motor idles up. The line routing is prob different for you and I would start by taking a light and looking under the passenger side for the lines. They were easy to get to for me. It could also be the actuator or the actuator linkage so be sure to check those also.
lincolnshibuya
Jul 5, 2020 03:05 AM
PaulH2
20
Jan 31, 2016 09:48 AM
14gt_Track
Oct 1, 2015 02:47 PM
guitarman376
Sep 30, 2015 05:54 PM
69Volunteer
Sep 30, 2015 10:39 AM
