More performance questions?
Old 10-26-2005, 07:16 PM
jdubb98
jdubb98's Avatar
Default More performance questions?
alright, i just ordered 3.73 gears for the rear end, a off road bbk x-pipe, a bbk cold air intake, and bbk underdrive pulleys, i was wondering what else i could order to get some more power, but for a decent price. i was thinking new throttle body and new intake plenum, what else would be some good suggestions?
jdubb98 is offline
Old 10-26-2005, 08:00 PM
sprostang
I ♥ Acer
sprostang's Avatar
Default RE: More performance questions?
Your gonna need a speedo recal or tuner to re-calibrate your speedo after installing the gears. I would go with the tuner. Theres alot more you can do with it. Get steeda pulleys instead of the BBK. Steeda are non piggyback, BBK are piggyback, which = bad choice for pulleys. You can get a nitrious kit for about 500. Alot less than a s/c. Also get some d/r`s, gonna need em for traction. Also a short throw shifter. Youll be happy with that but will still want to do more. Mods for a car just never seem to end.
sprostang is offline
Old 10-26-2005, 09:56 PM
03GTType
03GTType's Avatar
Get the accufab setup they've got the best results so far out of all the brands and they look the best IMO. Also grab a SCT 2 tuner for the gears and you'll be set.
03GTType is offline
Old 10-27-2005, 02:52 AM
jdubb98
jdubb98's Avatar
accufab setup? i'm fairly new to moding my cars i used to have a camaro but my dad did all the mods.
ORIGINAL: 01GTType
jdubb98 is offline
Old 10-27-2005, 02:54 AM
jdubb98
jdubb98's Avatar
alright nevermind i know what your talking about, i was thinking of going with all bbk, with a 75mm, i've been told it works best with aftermarket intake and new plenum.
jdubb98 is offline
Old 10-27-2005, 03:04 AM
jdubb98
jdubb98's Avatar
ok i just found a accufab 75mm throttle body and plenum for $409. was this what you were refering to or were you refering to the throttle body and egr spacer?
jdubb98 is offline
Old 10-27-2005, 04:56 AM
sandcracker21
sandcracker21's Avatar
he was refering to the TB and plenum, accufab is by far the best for this, however very pricy
i would go with a tuner, tb/plenum, and sum DRs
sandcracker21 is offline
Old 10-28-2005, 01:39 AM
jdubb98
jdubb98's Avatar
DR'S? What do you mean by DR'S? LOL Sorry for asking........
ORIGINAL: sandcracker21
jdubb98 is offline
Old 10-28-2005, 01:55 AM
03YellowPony
03YellowPony's Avatar
ORIGINAL: jdubb98
Drag raceing radial tires
03YellowPony is offline
Old 10-28-2005, 01:52 PM
sandcracker21
^^^ exactly, they will help you grip the road and help put more hp to the ground
it makes a HUGE difference from a take-off
Quick Reply: More performance questions?
