Please help: Limp Home mode/P2138
Old Jun 16, 2017 | 09:13 AM
BlueBeast08's Avatar
BlueBeast08
Default Please help: Limp Home mode/P2138
4.0L 2008 Coupe, no mods. I've had this car for almost 10 years, bought it with 63 miles on it. Two weeks ago the "limp-home" wrench showed up. Threw it into neutral, restarted the engine, wrench went away. Wrench came back after about 5 miles, now with a MIL. Checked the code with my scan tool and all it had was a P2138: throttle/pedal position sensor voltage error. Replaced the TPS, cleared the code, disconnected the battery to reset the PCM, and let it relearn idle. Drove fine to and from work for three days, then same wrench and MIL code. Replaced the pedal position sensor, reset PCM again. Same thing. Drove for about 15 miles and wrench/MIL came back right as I coasted into the parking lot. I'm thinking either it's a wiring problem (corrosion, short, etc) or maybe PCM that's on its way out. It's weird that it drives fine for a bit after every idle-relearn procedure/PCM reset (it seems not intermittent enough to be a wiring issue, but I could be wrong). OR it could be the entire throttle body, but I don't know why it's throwing P2138. Sorry for the long post; any thoughts/help would be greatly appreciated!
Old Oct 11, 2017 | 01:02 PM
LHO's Avatar
LHO
I'm dealing with the same issue. I have a 4.0L 2008 Coupe with no mods with 130,000 miles on it.
I was driving my car on the freeway and it fell into limp mode (wrench light on). I was able to safely drive off thinking my transmission went out. After, I took it to a mechanic and they said it was related to my throttle body and would charge me $900 to replace and reprogram my computer. I decided to just replace it my self and did. I did the disconnect battery relearn procedure but still had issues. I then took it to the dealer ship and they said aftermarkets sometimes don't work. I replaced with another throttle body and i got the same issue. I then replaced the pedal position sensor and did the relearn procedure again. This minimized the issue a lot but did not completely fix the issue. My car will now go into limp mode after a day or two of driving and will go away after I restart my car. I've been driving it like this for two weeks. So after all of this i don't know what is going on. Why would replacing my pedal position sensor help but not completely fix the problem. Why does restarting my car turn the wrench light back off and back to running normal for awhile . Why can my car run great for two days then fall back into limp mode?
Let me know if replacing your whole throttle body worked for you or if you find any fix. Thanks
Old Oct 11, 2017 | 02:52 PM
BlueBeast08
Default The answer will frustrate you
LHO,
After messing around with the pedal position sensor for way too long I decided to take a break for a week and then reattack with fresh eyes. As soon as I popped the hood I saw the problem. It ended up being a broken wire on the throttle position sensor harness. It was the grey one; the plastic sheath had that white spot you can see on wires where the interior wire has broken at a sharp angle inside of the plastic sheathing. I confirmed by straightening the wire out and taping it to a wooden splint, which made the wrench mode permanent, no longer intermittent. I used wire strippers to open it up and sure enough; broken wire. A simple re-solder job later, no limp mode. I would take an extra-close look at your wires again; hopefully the problem is close to your sensor like mine was. I feel bad that you’ve spent so much $$ already but the best lessons are sometimes the most expensive :/. Hope this helped; good luck!!
Old Mar 31, 2018 | 08:46 PM
Cmc10's Avatar
Cmc10
Default Limp Mode on a brand Spankin New 5.0
I purchased a brand new 2018 GT 5.0 about 2-3 weeks ago, with only 400 miles on it so far. Today was the first time I experienced the vaunted limp home mode. I’ve gotten it at least 7 times today. Took it to autozone and couldn’t get the wrench to come back so it didn’t generate any error codes. Called the dealership and they can’t check it out until Tuesday. Any ideas? Could it be throttle body issues like much of what I’ve read? I understand cars with mileage having some problems but this seems unreal... I appreciate y’alls feedback.
Old Sep 30, 2020 | 08:13 PM
1sick_gt's Avatar
1sick_gt
Were you able to able to fix your issue and what fixed it, I am currently in this situation,
I have my car for a year now and only mods i have roush catback and jlt cai with bama tune.
Old Sep 30, 2020 | 09:17 PM
Cmc10's Avatar
Cmc10
i was able to get mine fixed, but through some trial and error. I was still under warranty so I took it to a Ford dealership for troubleshooting. They first replaced the PCM, but the issues persisted. They eventually replaced the throttle body wiring harness and boom, haven’t had another issue with limp mode ever since.
Old Sep 30, 2020 | 09:20 PM
Cmc10's Avatar
Cmc10
Along with the roush no insert CAI, I’ve also since added 1 7/8 long tubes, cat back active exhaust and dyno tune. Car is running well and pulling 451 rwhp compared to about 385 rwhp stock.
