Spark plugs?
Old May 7, 2018 | 05:48 PM
David Brooks's Avatar
David Brooks
Default Spark plugs?
I have a 2010 GT 4.6L. My car was built on 09/2009. Do I have the spark plugs that break apart when you try to replace them or have they been replaced by Ford with spark plugs that don't fall apart. I have ask my Ford dealership and they tell me they should have been replaced in the 2010 models but cant really tell me for sure if Ford did. They said to try to remove one and see what hsppens. I don't want to go through all that hassle if it breaks off on me. Can anyone here help me on this!
Old May 8, 2018 | 07:23 AM
8 ball's Avatar
8 ball
The change was made mid-year 2008.......alas, 'bout 1 month after my GT was built.
Old May 8, 2018 | 02:30 PM
David Brooks
thank you!
Old May 8, 2018 | 03:08 PM
08'MustangDude's Avatar
08'MustangDude
Banned
I have an '08, I hope it's a midyear....
Old May 8, 2018 | 10:02 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Check a coil. If it has a brown boot, it’s newer. If it’s a black boot it’s the older design. Cutoff for old vs new is a build dat of nov 2007 or later. Everything prior to that was the older two piece problem plug.
Old May 9, 2018 | 04:57 AM
08'MustangDude
Banned
I have a coil pack, V6, so, not coil on plug... Does the same apply to the plug wires?
Old May 9, 2018 | 06:36 AM
JimC's Avatar
Super Moderator
The 4.0 never had the same issues with spark plug replacement. Just a difficult to reach plug at the back on the passenger side (angles back to the firewall so tight).
Old May 9, 2018 | 07:08 AM
ZEN357's Avatar
ZEN357
If you change them I'd would put a set of E3 Diamond Fire plugs in so you don't need to change them that often plus you get good performance from those plugs.
StangsR1
May 7, 2018 07:31 PM
jefffoster
Nov 6, 2008 01:05 PM
Black Mamba GTT
Dec 14, 2007 11:57 AM
91LXStang2727
Apr 21, 2006 04:08 PM
Dejavu
Jan 18, 2005 07:56 PM
