Rear end ID
Old Sep 18, 2018 | 10:36 PM
Flash gt's Avatar
Flash gt
Default Rear end ID
The rear end in my 2001 has been replaced before I bought it. The tag has the following letters and numbers. S229H SL28 88 0H10. Can anyone ID what gears the car has?
Old Sep 18, 2018 | 10:42 PM
Flash gt's Avatar
Flash gt
The SL88 MAY BE 5L88
Old Sep 18, 2018 | 11:27 PM
Urambo Tauro's Avatar
Urambo Tauro
From what I understand, the L in "#L##" means Trac-Lok, and the other numbers in that part of the code should represent the gear ratio. But those numbers don't sound right. Maybe try reading it again?
But hey it is a Mustang after all, so there's no guarantee that somebody hasn't changed the gearset inside. Only way to really be sure of the gear ratio without opening it up is to count driveshaft revolutions vs wheel revolutions.
Old Sep 19, 2018 | 10:26 PM
Flash gt's Avatar
Flash gt
You were right about rechecking the numbers. They actually say 3l27which I see means 3.27 gears. Don't know where I got 5l28 from.
Old Sep 26, 2018 | 07:01 PM
SmokyBC's Avatar
SmokyBC
Can you determine the rear axel ration from the info on the VIN tag?
Old Sep 26, 2018 | 07:56 PM
Urambo Tauro
The tag will tell you what gears were installed at the factory. It will not tell you if anyone's changed them since.
Old Sep 26, 2018 | 08:38 PM
SmokyBC's Avatar
SmokyBC
Thanks UT, is there a place where I can decode the info on the tag?
Old Sep 28, 2018 | 03:52 PM
SmokyBC's Avatar
SmokyBC
To answer my own question. From what I have learned, unless ordered otherwise, GTs come with a 3.55 rear axle.
Old Sep 28, 2018 | 06:53 PM
Flash gt's Avatar
Flash gt
You are correct. DD is the code for 3.55 rear axle.
Tberg725
Dec 4, 2008 12:34 PM
ARYANW
Feb 10, 2008 03:50 PM
91lxstang
Nov 18, 2007 06:08 PM
67fstback
Jul 31, 2007 07:10 PM
FordRacing302
Nov 6, 2005 12:59 AM
