Dirty CAI filter?
Old Nov 20, 2018 | 09:50 PM
kevsgt's Avatar
kevsgt
Default Dirty CAI filter?
Is it normal for the filter to turn black only in one area? Does this constitute a filter than needs cleaning or changing? Don't see much debris on it.
Old Nov 21, 2018 | 05:15 AM
08'MustangDude's Avatar
08'MustangDude
Banned
The air coming through the front of the car is hitting that portion of the filter. That is not a
CAI, it's a short ram. You can loosen the filter and turn it in 45 degree increments till you
have one solid band of dirt. Or, yeah, just clean it...
Your stock intake was actually a CAI, ^that's just to be pretty... A true CAI would be piped
into the fender well, and the cone or barrel filter would be inside the fenderwell. You won't
see one like that on my cars for $200+, I refuse to pay bloat for a pretty intake... There is one
for $35.00 on FB Marketplace, I would buy that, well, because it's $35.00.
Old Nov 21, 2018 | 08:17 AM
ZEN357's Avatar
ZEN357
If you replace the filter check out one of these...
https://greenfilter.com/
Old Nov 22, 2018 | 06:02 AM
David Young's Avatar
David Young
Clean it. I use the K&N recharge kit sold at my local auto parts store for around $20 and good for 3 or 4 cleanings. Always run the water from the inside to the outside of the filter
Old Nov 22, 2018 | 07:51 AM
Coosawjack's Avatar
Coosawjack
Truth is all of those filters will flow more than the engine can consume and cause no particular restriction until WOT or in a forced induction application.....if even then!!
Old Nov 22, 2018 | 02:12 PM
08'MustangDude
Banned
You can't tell anyone clean it with K&N recharge kit, you don't know if it's oiled or dry!
He didn't say either, so the guessing game is a'foot.
I have said that hundreds of times... Turbo and supercharged cars, it's different,
but almost every naturally aspirated engine is well below the CFM rating of
all those filters.
Old Nov 23, 2018 | 05:39 AM
David Young
[QUOTE=08'MustangDude;8640170]You can't tell anyone clean it with K&N recharge kit, you don't know if it's oiled or dry!
You can't see the picture?
Old Nov 23, 2018 | 09:57 PM
08'MustangDude
Banned
I have a red element filter, dry, blue, and green... You can't see that it's
oiled or not. Can't see the top if it says K&N or not, and he didn't even say
what brand it was. I am not gong to assume either way, and this is what
happens when people aren't detailed about their issues.
Old Nov 24, 2018 | 04:27 AM
David Young
I use the K&N recharge cleaning kit on my C&L cone air filter. 'Only' because it's sold at my local auto parts store. It's the same color (red dye) as the cleaning kit sold by C&L. If someone wants to have a blue tint to their oiled cone filter you can use the Mopar recharge cleaning kit.
Old Nov 25, 2018 | 07:55 AM
kevsgt's Avatar
kevsgt
Mine is a dry JLT filter. I will rotate it and see what happens with it. I'm not happy with the way it mounts to the tube. I've had it too loose and fall off, but too tight deforms the tube. Is it so difficult for them to put a lip on the tube for capturing the filter.
