Head bolt sealant
Old Feb 25, 2019 | 04:20 PM
Mikebell's Avatar
Mikebell
Default Head bolt sealant
Why do they recommend using Permatex 3H Aviation form a gasket on the head bolts? I am putting on some Trick Flow aluminum heads on a 1968 ford 302. The holes in the block seem to be "blind" or they dead end. How could any water get in---if that's the reason for applying?
Old Feb 25, 2019 | 11:40 PM
imp's Avatar
imp
Who is "they"? Only reason I could imagine would be as a thread lubricant. However, be aware that if a sufficient amount of the stuff got down in the hole in the block, beneath the end of the bolt, a "hydrostatic lock" condition could occur, robbing the bolt of needed tension: torque would be applied trying to compress the sealant, detracting from needed bolt tension to compress the head gasket.
Most Ford shop manuals recommend lightly lubricated head bolt threads using motor oil. BTW, hydrostatic lock has caused numerous failures of beaded steel head gaskets when sealant was applied to them: the sealant was trapped in the little valleys of the gasket, preventing proper compression of the material, and subsequent sealing.
(I worked in a head-gasket development lab for many years, at Victor Gasket Co.). imp
Old Feb 26, 2019 | 11:11 AM
proeagles's Avatar
proeagles
Some head bolts go into the water jacket on some blocks of some engines. If "they" are recommending the Permatex then "they" must think your application needs it.
Old Feb 26, 2019 | 12:35 PM
Derf00's Avatar
Derf00
Gentleman's Relish
As for why Aviation type RTV vs automotive, most likely for two reasons. It's anaerobic and can handle higher temps/oil/antifreeze. There are a couple of Automotive grade RTV's that can also handle it but the aviation grade is usually higher specd.
Old Mar 1, 2019 | 09:13 PM
Dave Rudd's Avatar
Dave Rudd
Proeagles is correct some of the head bolts probably go through water jackets and require sealant so they don’t leak. I’ve seen plenty of heads installed this way.
Old Mar 1, 2019 | 10:05 PM
imp's Avatar
imp
Obviously the guy who knows what he is doing probes all the bolt holes in the block before using sealer everywhere. imp
JC316
13
Feb 28, 2012 01:39 AM
jthorn9
Apr 4, 2011 11:22 PM
hunter5.0
Apr 9, 2007 01:41 AM
nit4gudtime
Feb 24, 2007 11:14 PM
byronstyle
Feb 18, 2007 02:45 PM
