Insufficent EGR Flow?
Old Oct 31, 2005 | 12:19 AM
HelpMe's Avatar
HelpMe
Default Insufficent EGR Flow?
Hey guys, I have a friend with a 2001 Mustang v6. The ECM is throwing a code, I went ahead and pulled the code, turns out to be "Insufficient EGR flow".
Now I checked the vac lines and they seem to be ok, also vacuum tested the EGR itself and it's functions properly. Which leads me to believe it's this thing in the pic below. Neither he nor I have a manual for this car, so could anyone tell me what this is and if it could be the culprit for the MIL?
If not, what else am I missing here? And If so, how much do they normally go for new?
Thanks!!!
Old Oct 31, 2005 | 01:38 AM
03YellowPony's Avatar
03YellowPony
Default RE: Insufficent EGR Flow?
ORIGINAL: HelpMe
Thanks!!!
Could be the EGR passage in the intake manifold is clogged. It happens all the time. Carbon builds up, and it clogs. Take the EGR off, and look in the manifold. If it's cloged, you will have to chip out the carbon. It can get real hard, so ytou might have to really dig at it.
Old Oct 31, 2005 | 05:51 PM
Zincpony's Avatar
Zincpony
i got that code after i got my car. its most likely isnt the valve it self but a corrupted o2 sensor. that is just the deal with my car.
Old Oct 31, 2005 | 06:01 PM
Derf00's Avatar
Derf00
Gentleman's Relish
DPFE switch for the Mustang. What normally goes wrong in Fords 1995 and newer that throw the "Excessive EGR Flow" or "insufficent EGR flow" codes.
And yes, it it most likely the culprit as it is in over 80% of those that have a similar code in their newer fords. Excessive means the switch is stuck open. Insufficient means it's stuck closed. You can take it off, clean it out, reset the computer and see if that fixes it. If it pops back on, it will need to be replaced.
Old Oct 31, 2005 | 06:31 PM
HelpMe's Avatar
HelpMe
Thanks for the tip guys. Now what does DPFE stand for? I take it the ECM tells this switch to turn on when at cruise? And when you say clean it out, cleaning the electrical contacts or the air passages?
Thanks a lot guys!
Old Oct 31, 2005 | 06:38 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Differential Pressure (switch) For EGR (DPFE) or Differential Pressure Feedback EGR (sensor).
It basically controls how much exhaust gas is allowed into the AIR tubes attached to the exhaust manifolds. You can try carb cleaner in the pipe side and electrical cleaner in the hose side. I haven't found these switches to really be cleanable.
Oct 26, 2015 05:01 PM
Luke9222
Oct 22, 2015 11:55 PM
fastbackford351
Convertible Tech
Sep 27, 2015 06:51 AM
TfcCDR
Sep 14, 2015 12:08 PM
Sep 10, 2015 08:39 PM
