ignition problem
Old Jul 24, 2019 | 01:00 PM
buttercup65's Avatar
buttercup65
Talking ignition problem
I need some help. My wife bought a '65 1/2 about a year ago. Yea that's her login name. You can call me either Rick or "Sarge". I can answer to either. Although I am not a skilled mechanic I was a "parts changer" in the Army many years ago so I have turned a wrench here and there. I do not have a good understanding of and very little experience with diagnostics. We have had the car in the shop more than once because at random turns it will not start but will only "click" once per starting attempt. I have inspected, cleaned and or changed out every terminal between the starter and the battery. (Did I mention I was a parts changer). We got it back from the shop (about four months ago) most recently after replacing the solenoid switch for the third time. Currently when she tries to start the car the starter will not disengage but continues to spin until the "hot" cable is removed from the battery post. My first thought was that the solenoid is bad but as I said we have replaced it several times. BTW this solenoid is mounted on the right fender well and not directly on the starter.
michaelyerry
Aug 29, 2013 09:20 PM
genec728
Apr 29, 2012 10:43 AM
Reef'd Up
Nov 12, 2009 03:00 PM
unit91
Apr 21, 2008 06:07 PM
ort4
Sep 17, 2006 05:50 AM
