Window goes down when I my door?
Old Mar 12, 2020 | 08:46 PM
David Flake's Avatar
David Flake
Default Window goes down when I my door?
Passenger's side window goes down whenever I open the door I have tried to reset the bump stop but no luck. Has anyone else experienced this problem?
Old Mar 17, 2020 | 07:33 PM
WJBertrand's Avatar
WJBertrand
Sounds like a short in the harness in the driver door that's bypassing the switch. Bending / flexing the harness when you open the door is causing the contact between wires.
Old Apr 2, 2020 | 10:59 AM
AlexAnderson's Avatar
AlexAnderson
Cause of trouble can be in the wiring harness or connector between body and door
Old Apr 9, 2020 | 07:34 AM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
When I replaced the window motor in my Navigator I went through a helluva dick dance trying to get it to behave properly. It kept going down or half-way up no matter how many times I followed the programming procedure. When I finally broke down and read the shop manual I discovered that there is a de-programming procedure that you must do first so you may want to coon around and see if there is a similar procedure for your car.
Old Apr 9, 2020 | 12:23 PM
Dexter2010's Avatar
Dexter2010
Default Try de programming it and then program.
Try to reprogram it then reprogram it.
stanginky
Jul 25, 2014 09:33 PM
Dencon
Jun 9, 2014 08:03 PM
polo708
Nov 16, 2008 06:18 PM
AirBrontosaurus
13
May 13, 2008 06:02 PM
Hash06
May 6, 2008 10:27 PM
