Engine failure
Old Nov 1, 2005 | 11:19 AM
lprice72001's Avatar
lprice72001
Default Engine failure
Engine failure
Recently had my engine rebuilt due to a leaky timing cover which caused me to have to rebuild the upper top twice. This time I decided to rebuild the whole block for estimated costs of $1300. $2100 and four weeks later (which encluded a new timing cover that was cut off, bored 20 over, new rings and pistons) we fianally got the engine back and put it in, hooked everything up. I had paid to have them put it togeather and prime the engine so it was all done right. Within 20 miles my engine checklight comes on and I limped it home the last mile. Had the machinist come look at it (I was pretty frustrated at this point) and he drove it to a friend of his who has a diagnostic center. Initially it read misfire in #6. They thought due to clogged fuel injector. Cleaned (and destroyed) my injectors and put a different set on and then it read no compression in #1. They were then telling me that we had put the camshaft positioning sensor unit in wrong and it caused the fuel injectors to be off time flooding the #1 cylinder, destroying the ring seals and that the engine needed to be rebuilt again to replace the seals. From what Im getting from the people Ive talked to (including ford) it would made the engine run rough but would not have caused engine failure and such severe damage to the engine. When we had it rebuilt I noted (and photgraphed) scoring in the cylinder walls after 20 miles. Another $1400 dollars later after the second rebuild (Iknow should have got a crate engine, isnt hindsight wonderful) the engine seem to run fine but engine checklight still on and reading malfunctioning CPS unit. We replaced it and cleared the code and seems ok now but have to wonder if that caused the engine failure like they said. Didnt buy it then and definitly dont now. Wouldnt have caused that damage to the cylinder walls. No gas noted in the oil, all the seals needed replaced (again) etc. The machinist who built it the first time just bought this shop and I think is still learning and is partially responsible (didnt seat the rings right, didnt replace the inner seals???) and he has totally washed his hands of any responsibility. Am thinking of taking him to small claims court to recoup some of my money. Anybody have any thoughts on wether putting the CPS unit in wrong would have caused that kind of damage or what would cause no compression in #1 after a total engine rebuild, the scoring in the cylinders, no oil to the cylinders, etc. Any opinions on his machine work. Any info I can get so when I go to court I can speak with knowledge on the situation. I am trying to get info from several different sources. Thanks...
Old Nov 2, 2005 | 10:43 AM
Chopper's Avatar
Chopper
Default RE: Engine failure
Destroyed cylinder walls after a rebuild is probably the result of not gapping the rings properly.This causes the ends of the rings to touch as they expand when the engine warms up.(the pistons heat up faster than the block)Since they are held in place by the piston,they try to eat their way out through the cylinder walls.The CPS was probably damaged before it was installed so don't reuse this one,buy a new part.Lastly,DON'T LET THESE "MACHINISTS" TOUCH ANYTHING EVER AGAIN!!!!!
Old Nov 5, 2005 | 01:02 AM
notched306's Avatar
notched306
i agree with Chopper and if the cps was bad it wouldnt have ran right if at all from the get go.Thats me assuming that it ran fine untill it hit 20 miles.just my 2cents
Old Nov 6, 2005 | 04:04 AM
BlkWidow's Avatar
BlkWidow
Regarding taking him to court - it all depends on what the receipt says. Is there any type of warranty or guarantee? If so, what does it say? How long has it been since it was rebuilt the first time? What state do you live in?
If the guy had any conscience at all, he wouldn't have charged you the last $1,400. since they obviously put the engine together improperly.
If there was no warranty & there's nothing you can do in court, at least report him to the Better Business Bureau. Always, always check out the people you are trusting to do such extensive work.
PM me with info regarding receipt if you want to. I have a lot of experience handling issues like this for my clients.
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
1TUFF302
Nov 5, 2015 04:02 PM
rksnow1
Sep 14, 2015 08:46 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
