Transmission Noise
Old Oct 23, 2021 | 12:11 PM
00MustangTEC's Avatar
00MustangTEC
Default Transmission Noise
Rattling coming from Transmission. It's a 5 speed. When I push the clutch in, the sound goes away. It shifts fine, doesn't slip, and sound goes away at 50mph or above. Throw out bearing?
Old Oct 23, 2021 | 01:53 PM
00MustangTEC
Also, it sounds like aluminum can bouncing around under the car.
Old Dec 8, 2021 | 07:24 AM
Jderek's Avatar
Jderek
I just saw your post today and if you haven’t fixed the issue it could be the transmission input bearing. The throw out bearing would make noise when you depress the clutch pedal as that’s when it’s turning.
I just did the one in my 2005. While transmission was out I did the pilot and throw out bearings too.
Old Dec 10, 2021 | 12:30 AM
00MustangTEC
Default Thank you
Thank you for the reply. Unfortunately, I found the issue. The input shaft is snapped in half. I blew a seal out going down the interstate and lost all of my oil. I probably should have towed the car but I was a long way from home.
hajii
Mar 26, 2011 09:18 PM
pennywise88
Aug 2, 2010 06:57 PM
yetihairball
Oct 16, 2006 12:15 AM
Dan9687
Sep 15, 2006 03:54 AM
Hiboost
Jan 21, 2006 01:54 PM
